Thread Number: 58090
Electrolux Compact Laundry |
Post# 805725   1/24/2015 at 14:19 (3,379 days old) by mrb627 (Buford, GA)   |   | |
Post# 805726 , Reply# 1   1/24/2015 at 14:21 (3,379 days old) by mrb627 (Buford, GA)   |   | |
Post# 805731 , Reply# 2   1/24/2015 at 14:28 (3,379 days old) by appnut (TX)   |   | |
Post# 805733 , Reply# 3   1/24/2015 at 14:43 (3,379 days old) by mrb627 (Buford, GA)   |   | |
Post# 805740 , Reply# 4   1/24/2015 at 15:02 (3,379 days old) by mrb627 (Buford, GA)   |   | |
Post# 805741 , Reply# 5   1/24/2015 at 15:06 (3,379 days old) by henene4 (Heidenheim a.d. Brenz (Germany))   |   | |
They are sold in some countrys arround Europe. The dryer does not recycle energy. It dumps it into the room. And the condensat tank is about 5l, so nearly 2 gallons. And you pretty much have to empty it every or every other load. And in fact, they do reverse! |
Post# 805743 , Reply# 6   1/24/2015 at 15:11 (3,379 days old) by mrb627 (Buford, GA)   |   | |
Post# 805744 , Reply# 7   1/24/2015 at 15:19 (3,379 days old) by jkbff (Happy Rock, ND)   |   | |
Post# 805762 , Reply# 8   1/24/2015 at 17:03 (3,379 days old) by logixx (Germany)   |   | |
Post# 805765 , Reply# 9   1/24/2015 at 17:31 (3,378 days old) by logixx (Germany)   |   | |
The dryers, by the way, have brushless motors like many Euro dryers these days. When using the Wool cycle, the drum spins for the most part of the cycle, preventing woolen items from excessive tumbling. The blower has its own motor, of course. Not sure if that feature will be included in the US version, though.
Post# 805768 , Reply# 10   1/24/2015 at 17:52 (3,378 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
These look to be the De-Luxe version of the AEG Protex range, the mid point of Electrolux Groups offerings.
Electrolux Laundry especially automatic washers and dryers have been around decades and are accredited both in Commercial and Domestic Home Laundry. It does make me smile that all Europe and other continents have a "Standard" range of appliances yest in USA are marketed "Compact" is it not that the rest of the world is normal and yours are "LARGE"? dunno!!
Post# 805774 , Reply# 11   1/24/2015 at 18:29 (3,378 days old) by henene4 (Heidenheim a.d. Brenz (Germany))   |   | |
Sure they have a seperate blower motor? I thought only Miele had this... |
Post# 805787 , Reply# 12   1/24/2015 at 20:02 (3,378 days old) by logixx (Germany)   |   | |
Post# 805872 , Reply# 13   1/25/2015 at 05:00 (3,378 days old) by henene4 (Heidenheim a.d. Brenz (Germany))   |   | |
But I guess that's exactly what not-tumble-drying needs ;) |
Post# 805873 , Reply# 14   1/25/2015 at 05:01 (3,378 days old) by foraloysius (Leeuwarden, Friesland, the Netherlands)   |   | |
I guess the French Electrolux TOL pair comes close to this pair.
Post# 805877 , Reply# 15   1/25/2015 at 05:33 (3,378 days old) by arbilab (Ft Worth TX (Ridglea))   |   | |
E-lux's previous 'extra rinse' implementation worked like this:
The 'e-r' switch turned on the pump halfway through the 3rd rinse. Then the waterlevel switch turned on spin. When the timer turned both those off it went into refill for the second half of rinse 3. Rinse 4 was always active though the timer dial labelled it 'extra rinse'. It was also 'warm' if warm rinse was selected but only the final rinse was warm. With the e-r switch off, rinse 3 simply tumbled twice as long, skipping pump/spin/refill. However, this applied to the clockwork timer. No idea how it's implemented in digital. |
Post# 805923 , Reply# 16   1/25/2015 at 10:31 (3,378 days old) by logixx (Germany)   |   | |
Post# 805935 , Reply# 17   1/25/2015 at 11:35 (3,378 days old) by mrb627 (Buford, GA)   |   | |
Post# 805954 , Reply# 18   1/25/2015 at 14:41 (3,378 days old) by logixx (Germany)   |   | |
Post# 805962 , Reply# 19   1/25/2015 at 15:58 (3,378 days old) by Suds (Brisbane, Australia)   |   | |
Post# 806002 , Reply# 20   1/25/2015 at 20:07 (3,377 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
The first thing I noticed is on the 27" full sized stack it looks like they have already abandoned the terrible one piece agi-tub, they may be using the same design that GE has been using for several years in its 27" and 24" stacks now that FD bought GEs appliance division. [ note GEs 24 and 27" stack washers have been having catastrophic failures in the washer part of their stacks, I have written estimates as high as $900 on machines that are just a few years old].
I would love to see proof that these compact condensing dryers use less electricity to dry a load of clothing, in my testing of a 1966 Frigidaire Filtrater dryer vs a 1970ish 29" WP dryer the FD uses at least 25% more power and I will not even comment on the slow speed of the FD. And of coerce they fail to mention the heat dumped in the house that the A/C has to remove [ more people world wide are moving to and living in warmer locations ] and again this dryer is not available in GAS which is a very popular way that makes doing laundry in the US more environmentally friendly than almost any washer-dryer system that relies on electricity for heating wash water and drying the clothing.
Other thoughts, I have never seen ANY clothes dryer that has brushes in the motor, also a number of dryers the world over have seprate motors for the tumbler and the blower, the little Italian built WP dryers sold here for about the last ten years have dual motors. |
Post# 806031 , Reply# 21   1/25/2015 at 22:09 (3,377 days old) by ronhic (Canberra, Australia)   |   | |
The last test done by our consumer magazine, Choice, confirmed that Heat-Pump condenser dryers used approximately half the electricity when compared to a normal condenser or vented dryer per KG of clothes.
So, regardless of load and size of machine, a Heat-Pump condenser will cost half the money to use than any other electric dryer.
Natural gas is approximately the same as a Heat-Pump dryer. However, we only have one natural gas dryer that is available domestically in our market and the majority of people would consider it nuts to run a gas line to the laundry. |
Post# 806078 , Reply# 22   1/26/2015 at 08:18 (3,377 days old) by mrb627 (Buford, GA)   |   | |
Post# 806129 , Reply# 23   1/26/2015 at 14:11 (3,377 days old) by ronhic (Canberra, Australia)   |   | |
All Electrolux machines get solid ratings. The EWF14912 which looks closest to the one in the original post scored:
Wash - 75% Rinse - 83% Gentleness - 71% Water efficiency - 87% Spin - 75%
Those results are from a machine with a capacity is 9kg. Choice, however, choose to test 3.5kg across the board as this is the average load that consumers wash regardless of machine size. Additionally, they test in tap cold water. In our market, this machine is $1500....so getting close to Miele money though the range does start at around $900 and less. Some of the lower priced machines scored 80% of dirt removal.
Post# 806154 , Reply# 24   1/26/2015 at 17:30 (3,376 days old) by logixx (Germany)   |   | |
I wouldn't be caught buying an Electrolux appliance because their company philosophy seems to be to swallow smaller companies, shut everything down and produce the machines as cheaply as possible.
That being said, AEG-branded laundry in Germany seems to be positioned more towards the higher-end section (think Kenmore Elite). Their washers and dryers get solid ratings by our consumer magazine - not Bosch or Miele, but okay. If you want to see them running, youtube "aeg protex". |
