Thread Number: 58262
Time for a new "Laundry Center" |
Post# 807817 , Reply# 1   2/5/2015 at 19:16 (3,361 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
The most reliable two are the nearly identical, MT, MET3800XW or WP, WET3300XQ, the dryer part of these two machines is the best dryer ever sold in a full sized stack. The washer section is still the tried and true DD washer mechanism with the cast-iron transmission. There is nothing unusual about a 2.5 CF washer and a 5.9 CF dryer, this is about the perfect ratio, a dryer should always be at least as large as a TL washer.
Next best choice would be the Frigidaire-Electolux stacks, but the dryer section has not improved one bit and while the washer may be about average in durability but sub-par in cleaning performance.
The GE stacks, RUN, RUN RUN away, we have been writing $900 estimates to repair the washer sections of their Full Sized stacks on 1+years old machines. The suspension struts are breaking and destroying the transmission and about every other part in the process. |
Post# 807855 , Reply# 2   2/6/2015 at 04:43 (3,360 days old) by henene4 (Heidenheim a.d. Brenz (Germany))   |   | |
Question: Could one of the new electronic SpeedQueen FL stacks work? |
Post# 807860 , Reply# 3   2/6/2015 at 07:29 (3,360 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 807866 , Reply# 4   2/6/2015 at 07:44 (3,360 days old) by logixx (Germany)   |   | |
