Thread Number: 58273
Maytag A206 Timer needed |
Post# 807907 , Reply# 1   2/6/2015 at 15:15 (3,359 days old) by rp2813 (Sannazay)   |   | |
Post# 807929 , Reply# 2   2/6/2015 at 18:32 (3,359 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 808020 , Reply# 3   2/7/2015 at 09:07 (3,358 days old) by lonestar ()   |   | |
I took it apart and has couple burnt contacts. Probably could rebuild it if I could find the contact strips. Thought someone here might have one. Thanks. |
Post# 808022 , Reply# 4   2/7/2015 at 09:21 (3,358 days old) by Kenmore71 (Minneapolis, MN)   |   | |
Rebuilding timers is an art and you will not find the parts you need except by taking apart another timer that has good contacts in it.
That is not a difficult timer to find as your original post noted. $85 may seem steep but that honestly is a pretty normal price for a timer on ebay. You might be able to find one for less somewhere else. |
Post# 808231 , Reply# 6   2/8/2015 at 14:07 (3,357 days old) by rp2813 (Sannazay)   |   | |
Keep pursuing this. Your Maytag is worth hanging onto. If no one here has a timer for you and $85 is all you need to spend to keep it running for any number of additional years, that's a bargain.
You could also check craigslist and see if there's a cheap or free Maytag you could harvest the timer and other parts off of for any future needs. |
Post# 808243 , Reply# 7   2/8/2015 at 15:02 (3,357 days old) by goatfarmer (South Bend, home of Champions)   |   | |
