Thread Number: 58275
Speed Queen - Are belts a common prob |
Post# 807906 , Reply# 2   2/6/2015 at 15:10 (3,360 days old) by rp2813 (Sannazay)   |   | |
Maybe Alliance has changed something in the design that makes switching out a belt easier.
Our Raytheon Amana/SQ clone ate belts (it had a relatively easy life, btw) and I've heard that current SQ machines still go through them. We wisely purchased an extended service contract with our Amana so it was always a tech who changed the belts on it. It was never a quick job and one of them even told me it wasn't as easy as on other machines. I watched one of them pulling off extraneous parts just to get at the belt. You'll hear a rhythmic dull clicking sound during agitation when the belt needs replacing.
So, if Alliance has made the job easier, then it's probably a minor annoyance to change out a belt once in a while in exchange for good old fashioned TL washing action.
A SQ tub will seem absolutely cavernous compared to the small capacity you've been dealing with on your 206. I made the same switch from a 206 to the Amana.
Sorry nobody has come forward to help you locate a timer for your Maytag. It sounds like a machine worth keeping (and $85 is way cheaper than a new SQ) if you don't mind its small capacity. |
Post# 807909 , Reply# 3   2/6/2015 at 16:03 (3,360 days old) by Yogitunes (New Jersey)   |   | |
not that your belt wont wear out over time for an Alliance built machine.....mine is around 8 years of heavy use, and still the original belt....
but its the Raytheon built ones that gave them all a bad rap.....this in detail had to do with that 4 port belt driven pump, pumping water back into the tub via the filter flume, just a bad design of pulling that said water from the bottom of the tub...in any case, it put excessive drag on the belt causing premature wear...later on that self clean filter set-up was removed...... |
Post# 807919 , Reply# 4   2/6/2015 at 16:57 (3,360 days old) by DigAPony ()   |   | |
The SQ belt change is a procedure compared to Dependable Care Maytags but certainly not a deal killer whether DIY or a service call and as Yogi mentioned the original drive belt can last 8+ years or more. |
Post# 807927 , Reply# 5   2/6/2015 at 18:10 (3,360 days old) by mrb627 (Buford, GA)   |   | |
Post# 807932 , Reply# 6   2/6/2015 at 18:49 (3,360 days old) by Nmassman44 (Brooksville Florida)   |   | |
Well from experience with my SQ washer and changing the belt out myself....it's no Maytag that's for sure. With a Newton built Maytag, one just tips the washer up and changes the belts in less than 3 mins flat, if that. The SQ washer requires the front panel to be taken off, then the top is tilted up, the pump is attached to the pump by clips so that has to be removed. Then the belt can be removed. One thing I noticed is all the black belt "dust" on the base of the washer. We bought my AWN 311 back in 2009 and it's still going fine. One thing with a worn belt one will notice dismal water extraction and it will take much longer for the wash basket to get up to speed. Agitation is affected as well. I have been noticing lately that there is a lot of chatter during agitation because of the idler, the transmission has some knocking going on now as well. But this is my experience, yours may vary.
Post# 807942 , Reply# 7   2/6/2015 at 20:12 (3,360 days old) by Yogitunes (New Jersey)   |   | |
Post# 807971 , Reply# 9   2/6/2015 at 22:27 (3,360 days old) by whirlykenmore78 (Prior Lake MN (GMT-0500 CDT.))   |   | |
Post# 808098 , Reply# 10   2/7/2015 at 18:18 (3,359 days old) by super32 (Blackstone Massachusetts)   |   | |
Post# 808221 , Reply# 13   2/8/2015 at 13:39 (3,358 days old) by rp2813 (Sannazay)   |   | |
I think there are enough testimonials about the belt issue to make the pursuit of a replacement timer for the Maytag your best option.
The TL Speed Queen boosters here may not want to hear it, but the fact is, the Alliance machines aren't any better at rinsing than our old Raytheon Amana was, and they tend to eat belts just as frequently.
After reading Mike's post, which captures the same issues we had with our Amana, I think you should reconsider. Your Maytag does a better job and won't need a single belt in the time period a SQ will go through a few of them. I'd hang onto it as long as possible. Just because SQ is the only old-school TL machine available on the market today, that doesn't put it in the same league with the build quality and performance of a '70s Maytag. Not by a long shot. |
Post# 808230 , Reply# 14   2/8/2015 at 14:01 (3,358 days old) by appnut (TX)   |   | |
Post# 808238 , Reply# 15   2/8/2015 at 14:32 (3,358 days old) by mrb627 (Buford, GA)   |   | |
The Amana washer and dryer set that I bought new back in 1996 are still running on the original belts (both washer and dryer) at my Aunt's house. Only repair they have ever had was a heating element on the dryer.
Perhaps the belts that you've been using are not factory authorized replacements? Malcolm |
Post# 808246 , Reply# 16   2/8/2015 at 15:28 (3,358 days old) by rp2813 (Sannazay)   |   | |
All service on our Amana was performed by Sears with factory parts.
I honestly think the belt thing is a manufacturing issue with many machines not being assembled to what may be highly precise specifications required for long belt life. There have been reports of a few stray machines that haven't had belt issues, but they seem to be the exceptions to an otherwise commonly reported complaint. |
Post# 809490 , Reply# 18   2/15/2015 at 19:40 (3,351 days old) by angus (Fairfield, CT.)   |   | |
Well, the serviceman was here yesterday and not only was it a belt, but the pump was leaking as well. Not sure how long pumps are supposed to last though. Start to finish - $220. Oh, well... |
Post# 809549 , Reply# 19   2/15/2015 at 23:51 (3,351 days old) by rp2813 (Sannazay)   |   | |
Post# 809653 , Reply# 20   2/16/2015 at 15:49 (3,350 days old) by Blackstone (Springfield, Massachusetts)   |   | |
gets used every day; I might have changed the belt & idler once, but I don't remember. Never touched the pump. However, I've changed the motor twice, and brake pads once.
I have no issues with the difficulty of changing this belt. Not at all, compared to all those years changing belts on old Whirlpools, laying on someone's damp, cold cellar floor, removing those spacers, and backing off the levers the right amount to make room for the belt. That is, of course, if I was able to loosen the rusty bolt tensioning the belt. |
