I just posted the July 1952 Issue of "The Review". This was GE's Engineering Magazine that highlighted all of the egineering advances of the time.
The July 1952 Issue has some great articles of interest to us vintage appliances collectors:
Such as:
Engineering the Automatic Washer
The automatic clothes washer is a simple device—to the housewife. She throws in the laundry, sets a control dial, and goes about her telephoning. A short time later she removes the laundry—washed and damp-dried.
Simply stated, the function of a domestic washing machine is to get the laundry clean, rinse out the detergent, and extract most of the water. For a third of the century these operations were performed with a machine in which the laundry was manually lifted from the tuh and fed through a water- extraction device. Most of these devices were wringers, powered by the washing- machine motor. A limited number were the centrifugal-extraction type using the same or a separate tub. article continues inside...
Dollar-sign Engineering
The photo sequence beginning on the next page will show you how a value analyst operates—step by step—on a typical project. Here, it’s the timer for the automatic clothes washer. Because space doesn't permit us to show the results of the analysis on every part of the timer, we have selected one part as being typical. (In the actual project more than 30 individual parts of the timer were analyzed for value.)
It should be emphasized that nothing was wrong with the timer when we approached the Value Analysis Unit and requested a survey. The timer operated satisfactorily and costs were in line with similar products. But. as is the case with far-sighted management, they wanted to see if it wasn't possible to further eliminate any unnecessary costs. article continues inside...
Cool Breezes — Story of the Electric Fan
Fans preceded written history by many centuries. Some of the most ancient known fans were those of the Chinese dating back to 3000 BC. And ceremonial fans were used in 1700 BC by the reigning monarchs of Egypt and Assyria. Some thousand years later the "punkah" —a hand-swung lightweight ceiling-suspended fan—was introduced in India, and even today is still in use there.
From exquisitely made folding tans of the Japanese, followed by 17th century Paris creations of surpassing beauty, we come to the practical palm-leaf type and simpler folding fans of grandmother’s day.
It’s not possible to give the exact age of the electric fan—the youngest member of the ancient family of fans. But the earliest record of a U.S. patent awarded for an electric fan was in 1854. This was a ceiling-suspended assembly of several large fan blades, each hinged along one edge to a horizontal rotating arm driven by a battery-operated motor. Arms on the blades struck projections causing the blades to vibrate and thus agitate the air. article continues inside...
CLICK HERE TO GO TO Unimatic1140's LINK
