Thread Number: 58358
Same procedure as every year, James.. |
Post# 808887 , Reply# 3   2/12/2015 at 06:19 (3,332 days old) by henene4 (Heidenheim a.d. Brenz (Germany))   |   | |
After the soaking time, I used the service cycle to give the AEG a quick rinse. The display shows the fill level in mm above the lowest point of the tub. (Though this seems wrong, the tub is formed quite oval as this tub design is used with the steam models and the cavity at the bottom of the tub stores and holds the water while steaming.) |
Post# 808901 , Reply# 6   2/12/2015 at 08:59 (3,332 days old) by dave886 (united kingdom)   |   | |
Can i use this method in a LG washing machine? |
