Thread Number: 58395
New to me 1-18 |
Post# 809126 , Reply# 1   2/13/2015 at 17:50 (3,351 days old) by appnut (TX)   |   | |
Post# 809127 , Reply# 2   2/13/2015 at 17:50 (3,351 days old) by Northwesty (Renton, WA)   |   | |
Seems to be working. If I gave it the spa treatment it actually wouldn't look too bad. Anyone out there know the year? It has the fake wood grain on the control top.
Post# 809130 , Reply# 4   2/13/2015 at 17:56 (3,351 days old) by Northwesty (Renton, WA)   |   | |
Sounded real good. Thanks for looking didn't think I would ever pick one of these up. Brian -- again look at that tub discoloration. Any idea on how to get that off?
Post# 809143 , Reply# 5   2/13/2015 at 19:41 (3,350 days old) by laundromat (Hilo, Hawaii)   |   | |
Post# 809153 , Reply# 6   2/13/2015 at 20:47 (3,350 days old) by revvinkevin (Tinseltown - Shakey Town - La-La Land)   |   | |
Very nice machine Brian! I'm sure you'll enjoy it!
I would guess it's mid-ish (or later?) 70's.
General Motors sold the Frigidaire Appliances division to WCI in 1979..... so the 1-18 was just a distant memory by 1986 / 87.
BTW... as Nate (Roto204) will attest to, these hold a lot! Also, as for water level, as odd as it may sound, with the 1-18, "less in more". You will get better movement (turn/roll-over) if you slightly under-fill it for any given load.
Kevin |
Post# 809164 , Reply# 7   2/13/2015 at 21:50 (3,350 days old) by Kenmore71 (Minneapolis, MN)   |   | |
Post# 809168 , Reply# 8   2/13/2015 at 21:59 (3,350 days old) by pumper (SE Wisconsin)   |   | |
Post# 809179 , Reply# 10   2/13/2015 at 22:32 (3,350 days old) by PhilR (Quebec Canada)   |   | |
It has the earlier type "bed-of-nails" lint filter so I don't think it's a "WIB" or "WIG" as both of these had the later pan type.
Look at the model and serial number sticker. It should be a WC and the serial number should begin by a 6 or 7. This model was made from late 1975 to 1977 as 1976-77 models but it's not older than late 1976 as the lid switch is located under the control panel (earlier models had it under the top behind the rear hinge of the cover).
If you could post a picture of the serial number, it's right behind the timer at on the angled part at the top of the back cover. |
