Thread Number: 58504
1964 Multimatic Video |
Post# 810333   2/20/2015 at 19:45 (3,345 days old) by cadman (Cedar Falls, IA)   |   | |
For those that are "into that sort of thing" ; ) I've posted a condensed wash video of my '64 Frigidaire at the link below. This was one of the first machines I found years ago and still does a great job when washday rolls around. -C
CLICK HERE TO GO TO cadman's LINK |
Post# 810341 , Reply# 1   2/20/2015 at 20:30 (3,345 days old) by washman (o)   |   | |
love the spin drain. |
Post# 810346 , Reply# 2   2/20/2015 at 20:51 (3,345 days old) by scoots (Chattanooga TN)   |   | |
I think I'm in love. The agitator has always reminded me of the Gemini space capsule. I wonder if that helped link the product with the subliminal "Space Age" message of the time.
Post# 810352 , Reply# 3   2/20/2015 at 21:30 (3,345 days old) by norgeway (mocksville n c )   |   | |
Washer!Not this junk made today! |
Post# 810377 , Reply# 4   2/21/2015 at 00:18 (3,345 days old) by A440 ()   |   | |
That is one Sturdy Washer!
Post# 810385 , Reply# 5   2/21/2015 at 02:18 (3,345 days old) by PhilR (Quebec Canada)   |   | |
Post# 810390 , Reply# 6   2/21/2015 at 03:51 (3,345 days old) by gregingotham (New York)   |   | |
I love the design and style of this machine as well as how well it works. Has it been rebuilt or is it in original working condition? where did you find it? |
Post# 810692 , Reply# 8   2/22/2015 at 20:25 (3,343 days old) by PhilR (Quebec Canada)   |   | |
Gary, I remember you posted about this problem of yours some time ago. Mine needed some work too as the mechanism wouldn't even turn. I replaced a few parts in it but when I reassembled it, it did like yours, I disassembled it again the same day and it was just a part that I didn't assemble correctly (I didn't push it far enough inside the mechanism). Since yours hasn't been dissasembled, I suspect it has a different problem that causes the tub to turn when agitating. Does it just turn slowly or it turns fast enough to spin the water out if you let it go? It could be broken torque spring in the transmission. |
Post# 810741 , Reply# 9   2/23/2015 at 08:24 (3,343 days old) by cadman (Cedar Falls, IA)   |   | |
Hi Greg,
I actually rescued the pair (this and the matching gas dryer) from the scrap area of a local appliance shop many yaers ago. With Ben's help we changed the trans oil, installed new belts and I recall making a new gasket for the waterpump. It likely would have worked fine as-is but I figured now was the time. The machine is surprisingly quiet, but you'll note the cone is a little loud- that's because it has a couple broken alignment teeth and 'squawks' just a bit. Otherwise it purrs like a kitten! -C |
Post# 810753 , Reply# 10   2/23/2015 at 10:50 (3,343 days old) by abcomatic (Bradford, Illinois)   |   | |
HI Phil, The tub spins fast enough to spin the water out. Oh well. Thanks, Gary |
Post# 810755 , Reply# 11   2/23/2015 at 10:57 (3,343 days old) by PhilR (Quebec Canada)   |   | |
Post# 810811 , Reply# 12   2/23/2015 at 17:48 (3,343 days old) by abcomatic (Bradford, Illinois)   |   | |
Phil, Yes I have the service manual. |
Post# 810935 , Reply# 13   2/24/2015 at 13:48 (3,342 days old) by Jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Post# 811433 , Reply# 15   2/27/2015 at 08:48 (3,339 days old) by cadman (Cedar Falls, IA)   |   | |
Thanks Joe, your comments are much appreciated! Truth be told, I use to mess around with video quite a bit years ago, but it's been at least a decade since I've picked up the camera...just got busy with other things : )
I hope to start weekly uploads of all sorts of odd and interesting equipment around here, at least while it's 10 below outside. -C |
Post# 811505 , Reply# 16   2/27/2015 at 19:21 (3,338 days old) by lotsosudz (Sacramento, CA)   |   | |
Post# 811509 , Reply# 17   2/27/2015 at 19:44 (3,338 days old) by PhilR (Quebec Canada)   |   | |
Depending of the year and model, the spin speed of the domestic Multimatic machines varies between 700 and 850 RPM.
The 1963-64 models with the 12 pounds tubs have 710 RPM speed while the earlier models with the 9 pounds tub either have 700 or 850 RPM spin speed. My 1960 Deluxe has 700 RPM spin according to the Tech Talk manual. The "Rapidry" models had 850 RPM spin until they stopped to offer the 9 pounds tubs.
The newer coin-operated/commercial Multimatic machines like 1966 Robert used to have had 1000 RPM spin to match with the new Rollermatic Rapidry models.
Here's a video of my 1960 spinning:
Post# 811554 , Reply# 18   2/28/2015 at 08:18 (3,338 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Yes indeed Great Videos Cory.
Hi Phil, My 1962 WCI-62 washer still has the speed shift to the faster 850 RPM spin speed, apparently they discontinued the faster spin mid year.
My question was there really difference in actual tub capacity between 1961 and 1964 or did FD like so many other washer builders just claim that their washers could wash a bigger load, I never noticed any difference. |
Post# 811638 , Reply# 19   2/28/2015 at 19:18 (3,337 days old) by PhilR (Quebec Canada)   |   | |
The tubs changed. Compare your early Multimatic tubs to one of your Rollermatics (which are also rated at 12 pounds). They seem to have the same depth but the newer tubs seem to be approximately 1" larger in diameter than the older ones. As for the claimed capacity. I guess you need to find some very heavy material to be able to fit loosely in either of these the advertised dry clothes capacity! Maybe if you wash pants and leave a lot of change in the pockets you could achieve this! Just avoid leaving screws and nails with the change! |
Post# 811673 , Reply# 20   3/1/2015 at 00:05 (3,337 days old) by Jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Robert cram his Frigidaires full, to my horror, yet he still gets roll over out of them. He's a closet stuffer IMHO!! Yes the 12 pound tubs are bigger if you stack a 1960 tub on top if a 1963 tub you can see the difference and if you look at the cabinets they are bigger too. 1960 was the last year of the 1950's sized cabinets because the larger tubs demanded more room to oscillate at critical speed.
Post# 811748 , Reply# 21   3/1/2015 at 12:17 (3,337 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 811760 , Reply# 22   3/1/2015 at 14:07 (3,337 days old) by PhilR (Quebec Canada)   |   | |
John, You're right about the cabinet sizes that changed in 1961 (both washers and Filtrator dryers went to 27" cabinets) but while the Filtrator dryers were all new and now 27" wide like the previous (and 1961) vented models, the washers didn't change much internally that year. The 1960 and earlier Frigidaire washers were 25" wide (25½ is Maytag!).
I don't have a 1961-62 machine to measure (I wish I had one as I have a lonely 1961 clamshell dryer!). But according to my Canadian parts books, the part number is the same for all 1957-62 tubs and changed in 1963. I don't know if the Canadian part numbers all match with the US part numbers so there might be some differences in some US parts books...
The first picture shows 1960 and earlier parts numbers (part #5439222 for 1957-60). #2 is from the 1957 parts manual (shows same part number as in 1960-#5439222) #3 is from the 1961 parts manual (#5439222) #4 is from the 1962 parts manual (#5439222) #5 is from the 1963 parts manual (#7522865) #6 is from the 1964 parts manual (#7522865) #7 is from the 1965 parts manual (#7523974)
There are hand-written part numbers which I guess were either Canadian or US variants or numbers that superseded the original numbers. Some Canadian machines have different porcelain coating on their tubs but it seems that some Canadian parts books are copies of US parts books. This post was last edited 03/01/2015 at 14:25 |
