Thread Number: 58527
/ Tag: Modern Dishwashers
Bosch SHE4AM12UC dishwasher hasn't been draining |
Post# 810993 , Reply# 1   2/25/2015 at 00:12 (3,346 days old) by laundromat (Hilo, Hawaii)   |   | |
Put a nail into the sidewall of your lower cabinet to hang the hose on a loop or upside down "U". Otherwise,there's"backwash" reversing back into the tub after it's done pumpout. The old KitchenAids with gravity drain were best at preventing that but are far gone now. Some of our customers , after replacing their garbage disposals, had no idea in order for their dishwashers to drain properly, they'd have to punch out the molded male piece, that protrudes out for the dishwashers drain hose to be clamped on so it drains into their disposer/drain. Not doing that causes the water to stay inside and never drain. Then,thinking it too was broken, they'd replace a young model , nothing wrong with it,take home a brand new one only to return it claiming the same problem in drainage as their,now far gone,older model. The shit hit the fan once they found out the real problem,owner ignorance. I wound up having a sign, up on the wall showing the correct way to install a new disposal with or without a dishwasher connection.
