Thread Number: 58589
Maytag A206 with sluggish agitation - Cold Weather Problem? |
Post# 811253   2/26/2015 at 08:00 (3,339 days old) by scoots (Chattanooga TN)   |   | |
I have a Maytag 206 and since the weather's gotten cold (and the unit is kept in the unheated basement) when the machine is first used the agitator crawls along at a full oscillation every two seconds. Shifting between speeds does not help, spin speed is not affected. There are no unusual sounds. The agitator cannot be brought to a stop by hand.
The speed gradually increases with time. With a hot water load the speed is up to normal in about 2 minutes and remains there for as long as the machine is in use.
I suspect that what's happening is the oil in the transmission case has gotten too thick when cold, inhibiting free agitation. The belt may be silently slipping, or the motor is being held in check (reduced RPM) because of the extra resistance from the gear box. As the machine is brought up to temperature, the viscosity improves and the problem goes away.
As mentioned, the unit is in an unheated basement. Out door temps right now are in the night time 30s, with the basement probably in the 40s.
For my next load, I will fill the tub with hot water and let it sit for 5 minutes or so to see if this improves the situation until the cold weather passes.
Comments, quick remedies, and actual solutions are welcome.
Post# 811255 , Reply# 1   2/26/2015 at 08:15 (3,339 days old) by Kenmore71 (Minneapolis, MN)   |   | |
You are spot on diagnosing the issue.
The fact that you cannot stop the agitator by hand tells me that the motor carriage springs and belt are good.
The belt is slipping (as it is designed to) until the transmission warms up and can achieve normal speed agitation. If this slipping weren't happening, the motor would overload and eventually overheat and go into thermal shutdown.
The quick and easy remedy is make sure that the transmission is warm before you begin.
The long term solution is to pull the transmission, open it up and replace the oil. (BIG job)
Post# 811290 , Reply# 2   2/26/2015 at 11:08 (3,339 days old) by kenwashesmonday (Carlstadt, NJ)   |   | |
My Maytag A606 is next to a drafty door in the basement and does the same thing on a cold day. I usually warm it up by washing a warm gentle load first, after which it's ready for the rest of the laundry. Ken D. |
Post# 811313 , Reply# 3   2/26/2015 at 13:18 (3,339 days old) by rp2813 (Sannazay)   |   | |
Post# 811318 , Reply# 4   2/26/2015 at 13:59 (3,339 days old) by Yogitunes (New Jersey)   |   | |
one of those tiny square space heaters would help a lot if placed near one of the rear openings for roughly 30 minutes to an hour before hand...once the machine got heated up, you will be good to go.....
a heat gun or blowdryer can work too.... had this when a machine was in an unheated storage room, where the pump and any water in the machine froze as well.....this worked well during the winter months, also took part of the dryers vented air to heat the room afterwards.... you just have to schedule your wash to a certain day/time...if you have to go through all this effort, make it worth it and do it only once or twice a week... |
Post# 811335 , Reply# 5   2/26/2015 at 15:44 (3,339 days old) by cleanteamofny ((Monroe, New York)   |   | |
My Direct Drive washer Spin drains during the first or second load when I was using it but once it was throughly warmed up, everything goes back to normal. This happens when the temp in the house is around 60*.
Post# 811356 , Reply# 6   2/26/2015 at 18:49 (3,339 days old) by appnut (TX)   |   | |
My DD Kenmore did the same thing Larry's did. I began wash day with it going through the entire 6 minute final spin, sometimes even the drain segment where it spun too. then each subsequent load behaved as designed. So see about putting it through an entire final spin dry before you begin washing and see if that helps. (fast speed of course). |
Post# 811360 , Reply# 7   2/26/2015 at 19:06 (3,339 days old) by pierreandreply4 (St-Bruno de montarville (province of quebec) canada)   |   | |
There is also the option to fill your washer with hot water no agitation of course you leave the hot water in the wash tub so that it heats or warm your washer then you drain the hot water let it go true spin (you set your washer on the final spin of course then wash as normal since the washer will have warm up
Post# 811365 , Reply# 8   2/26/2015 at 19:16 (3,339 days old) by lovestowash (St. Petersburg, FL)   |   | |
I have both a Maytag 124, and a Kenmore Series 90...both in the basement...it's finished, but still remains cool in the Winter...
I knew about the sluggish behavior of the Maytag, but had no idea of the temperature affecting the spin/drain in the Kenmore...and mine has behaved as described... I thought the immediate spin was just a stroke of luck... Thanks guys... George |
Post# 811367 , Reply# 9   2/26/2015 at 19:21 (3,339 days old) by appnut (TX)   |   | |
Post# 811376 , Reply# 10   2/26/2015 at 20:05 (3,339 days old) by washerlover (The Big Island, Hawai’i)   |   | |
Post# 811378 , Reply# 11   2/26/2015 at 20:34 (3,339 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Hi Bill, You are correct that MT helical drive washers don't like cold weather, they also don't like actually washing big loads and doing any real work. This has long been one of my biggest grips with most HD MT washers. When MT introduced this machine in 1956 they did not have this problem, the orignal machines had a proper belt tension system for the main drive belt that would properly power the transmission during agitation and allow a nice gentle acceleration into spin while the water was being pumped out. Problem was they changed to an idiotic belt tension system that allowed the drive to SLIP during agitation and Maytag produced another FIRST in automatic washer design, they built the first and ONLY washer whose agitation slips instead of turning over a load of clothing.
No other washer ever did this, NOT WP, Not GE, Not Norge and on and on No one ever built such a lame design and built them for so many years.
The good news is that MT finally largely fixed this serious problem after they started building the Orbital Transmission washers and they moved the springs to one side of the motor carriage, it only took them 30 years and millions of lame washers to fix a design problem that should have not been built for more a year or so. |
Post# 811409 , Reply# 12   2/27/2015 at 04:43 (3,338 days old) by arbilab (Ft Worth TX (Ridglea))   |   | |
Yep my '06 did that. To cut wear, I started it on slow speed-- since it only goes that fast anyway when it's cold-- then came back after a few min and switched to high. No trouble, I came back after a few min anyway to check detergent dose.
Speaking of no trouble, I bought the thing used, ran it for 10 years and gave it to a coworker when I got my electro-frigi-white tumbler. Never put a penny in it. Just office clothes which it handled fine. |
Post# 811421 , Reply# 13   2/27/2015 at 07:06 (3,338 days old) by super32 (Blackstone Massachusetts)   |   | |
Post# 811431 , Reply# 14   2/27/2015 at 08:29 (3,338 days old) by bajaespuma (Connecticut)   |   | |
I guess "Dependability" came at a cost of performance.
Our GE's didn't blink. |
Post# 811491 , Reply# 15   2/27/2015 at 17:58 (3,338 days old) by scoots (Chattanooga TN)   |   | |
Some of your answers made me smile, especially John's funny rant about Maytag being industry slackers. I have found that if I fill the machine up with hot water and let it sit for 5 minutes, then do a "warm" wash (after the water's heat is lost to the steel) it does ok for the rest of the session. I'm going to let sleeping dogs lie for now.
This only came to my attention recently when I installed a bye-pass switch. As you all probably know, Maytag has an infuriating "STOP EVERYTHING" feature so that if you lift the lid, everything stops. I was getting tired of playing peek-a-boo with the tub trying to see if the turn over and water levels were OK, so I installed a toggle switch on the back of the control board that cuts out the open lid switch so I can watch the machine's performance.
God knows how long this slipping has been going on... sigh. |
Post# 811574 , Reply# 17   2/28/2015 at 10:54 (3,337 days old) by jamiel (Detroit, Michigan and Palm Springs, CA)   |   | |
I had an old Maytag in an unheated garage in Chicago--always had to leave the light on to use it so it wouldn't freeze. Ended up replacing it with an Estate (Whirlpool) World Washer--figured that design would be the hardiest in the cold given the design was intended to be uniform the world over...bought it from Plass Appliance at the end of the block and borrowed their hand truck to bring it home :)
