Thread Number: 58618
/ Tag: Vintage Dishwashers
POD 3-1 1953 Hotpoint DW |
Post# 811695   3/1/2015 at 06:32 (3,337 days old) by arbilab (Ft Worth TX (Ridglea))   |   | |
Now you know exactly what the first dishwasher I ever used looked like. The one that flooded the kitchen twice. Once when the water valve stuck, once when I put washer detergent in it. The next (57) wasn't much different except it never flooded.
The good old ramp-and-baffle 4-blade bakelite impeller sitting directly atop the motor shaft. The good old motor-current relay that turned the water off. 2 washes, 2 detergent compartments, 2 rinses. Water entered from a sprinkler at the top, which probably rinsed better than the subsequent side entrys. I'm pretty sure it had a standalone pump. I'd be absolutely sure if it had ever given a problem. We had no performance complaints. BUT back then detergents were packed with phosphates AND I was taught to douche all the lumps off, leaving only a film of grease for the machine to remove which it did handily. Oh, at the time I was 8yo and venturing into repairing the 1949 Laundromat. Thoze werr da daze. |
Post# 811731 , Reply# 1   3/1/2015 at 11:11 (3,337 days old) by appnut (TX)   |   | |
Post# 811886 , Reply# 2   3/2/2015 at 05:44 (3,336 days old) by arbilab (Ft Worth TX (Ridglea))   |   | |
Post# 812098 , Reply# 3   3/3/2015 at 04:37 (3,336 days old) by arbilab (Ft Worth TX (Ridglea))   |   | |
