Thread Number: 58674
Kenmore agitator shaft- opinions |
Post# 812382   3/5/2015 at 01:00 (3,339 days old) by ladyk (Tacoma)   |   | |
I need some expert opinions. Is this agitator shaft good enough to use? I've got a new basket drive and don't want to screw it up! Lol
Post# 812395 , Reply# 1   3/5/2015 at 07:46 (3,338 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Yes this shaft will work, BUT the top seals in your new basket drive assembly will quickly be ruined, so if this is to be an every-day-driver it will only last a year or so before you have problems with moisture getting into the agitator shaft bearings and possibly the transmission.
If you want to use this machine much get a NEW or at least a nearly perfect used one, if you use a used AS from a post 1980 machine the top seal area that is in bad shape on your shaft is nearly always perfect because the spin-tube was 6" shorter so there is never any seal wear near the top of the shaft.
