Thread Number: 58681
Exploding Direct Drive? |
Post# 812508 , Reply# 1   3/6/2015 at 00:16 (3,332 days old) by tolivac (greenville nc)   |   | |
Has this got to be one of the first WP/KN machines that has Spin-sploded? |
Post# 812519 , Reply# 2   3/6/2015 at 05:01 (3,332 days old) by washdaddy (Baltimore)   |   | |
Looks like the result of someone throwing a cinder block into it while it was spinning. Would like to know what they were washing in the machine at the time this happened. |
Post# 812541 , Reply# 3   3/6/2015 at 07:50 (3,332 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
I have seen similar things happen a few times on DD washers. It has usually been caused by one of several failures like, a broken basket center-post, a broken balance ring, loose suspension clamps and springs and of coarse if you drop a cinder block in the washer when it is spinning at full speed this could happen, LOL.
It is not really a big deal when you consider how many of these machines they made and how seldom anything like this happens, and I will bet you the machine was showing signs of problems that were being ignored by the user-owner before this [ JUST ] happened, LOL. |
Post# 812542 , Reply# 4   3/6/2015 at 07:50 (3,332 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 812547 , Reply# 5   3/6/2015 at 08:16 (3,332 days old) by mrb627 (Buford, GA)   |   | |
Seems like a lot of white powdery substance on the outside of that wash basket. Is that from the plastic outer tub? Wonder if something in the wash load was able to slip through a tub hole and grate against the outer tub...
Pic 2 appears that the balance ring is down inside the tub. Perhaps the most likely culprit? Kind of reminds me of the Seinfeld episode where Kramer put a 50lb bag of Sacrete in a coin washer at the Laundromat. Malcolm |
