Thread Number: 58801
remounting Kenmore outer tub |
Post# 813882   3/14/2015 at 00:11 (3,324 days old) by ladyk (Tacoma)   |   | |
Can a guy use rubber washers instead of cork to mount the tub to the baseplate? |
Post# 814071 , Reply# 1   3/15/2015 at 15:17 (3,322 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 814078 , Reply# 2   3/15/2015 at 17:15 (3,322 days old) by thefixer ()   |   | |
As warned, don't go over 1/16" thick. The flange on the short rubber tub outlet hose is sandwiched between the tub and the baseplate. If your washers are too thick, you won't get a good seal there and it's going to leak. |
Post# 814101 , Reply# 3   3/15/2015 at 19:47 (3,322 days old) by ladyk (Tacoma)   |   | |
Thank you so much. I'll go get some cork! |
