Thread Number: 58901
Zanussi IZ16S |
Post# 814690   3/19/2015 at 03:47 (3,325 days old) by Newwave1 (Lincoln, United Kingdom)   |   | |
Hey all,
Well my latest find I have wanted since the day they were released. A Zanussi IZ16S. A fantastic and innovative machine with a 15deg inclined drum and recirculatory jet and 1600rpm drum amongst others. Here's the problem. I was told it was fully working when in actual fact the bearings are knackered. I thought my luck of late would be knocked at some point. After some dispute they have agreed to a part refund and I will replace the bearings. Not a great first gumtree purchase. There is a video of the one and only cycle I will run until it's repaired on my YouTube linked below Darren CLICK HERE TO GO TO Newwave1's LINK
Post# 814730 , Reply# 1   3/19/2015 at 08:31 (3,325 days old) by henene4 (Heidenheim a.d. Brenz (Germany))   |   | |
I knew these were avaible in slimline as well. A german collector once had a pretty simmilar one to yours in a slimmer depth with equally bad bearings. Given these machines look pretty simmilar on the inside to any of the E-Lux range with that UI, changing bearings is quite a job, but do-able... |
Post# 814788 , Reply# 2   3/19/2015 at 17:03 (3,324 days old) by Newwave1 (Lincoln, United Kingdom)   |   | |
Post# 814891 , Reply# 3   3/20/2015 at 09:29 (3,324 days old) by Newwave1 (Lincoln, United Kingdom)   |   | |
Post# 814996 , Reply# 4   3/21/2015 at 09:07 (3,323 days old) by Newwave1 (Lincoln, United Kingdom)   |   | |
Post# 814998 , Reply# 5   3/21/2015 at 09:08 (3,323 days old) by Newwave1 (Lincoln, United Kingdom)   |   | |
Post# 820774 , Reply# 7   4/24/2015 at 14:37 (3,288 days old) by optima (Cumbria England)   |   | |
Great news Darren that you have got yourself a fully working IZ, i was lucky to come across this beauty a ZANUSSI INPUT WD15 Washer/Dryer.
Post# 820854 , Reply# 8   4/25/2015 at 01:45 (3,288 days old) by Newwave1 (Lincoln, United Kingdom)   |   | |
Romany-I have the same problem. I love jeysystem machines and I ordered a model that was supposed to have it but AEG dropped it from all models except the top 2 models. You wouldn't be able to make it happen unless you got a new pcb, pump and hosing and seal identical to a model that has it.
I recently modified my Bosch logixx (nexxt) to have the cascade fill most Bosch machines have. This was easier because it I created a splitter and ran a hose to the door seal. I need to do the same on both solenoids to make it fill through it during every stage of the programme. Darren
Post# 820855 , Reply# 9   4/25/2015 at 01:47 (3,288 days old) by Newwave1 (Lincoln, United Kingdom)   |   | |
