Thread Number: 59172
Visit to Jeff's Westinghouse collection in Mansfield, OH! |
Post# 817334   4/3/2015 at 19:20 (3,304 days old) by moparwash (Pittsburgh,PA )   |   | |
OH! is the way do describe it!...I was in Cleveland for work again for a few days and made the trip to see them in person!..These are all just a few miles from their birthplace former W Mansfield Plant! Thanks to Jeff for his wonderful hospitality!..I should of taken more pictures!
First up of the Laundromat set with the 'How Dry I am Dryer! |
Post# 817335 , Reply# 1   4/3/2015 at 19:22 (3,304 days old) by moparwash (Pittsburgh,PA )   |   | |
Post# 817336 , Reply# 2   4/3/2015 at 19:23 (3,304 days old) by moparwash (Pittsburgh,PA )   |   | |
Post# 817337 , Reply# 3   4/3/2015 at 19:25 (3,304 days old) by moparwash (Pittsburgh,PA )   |   | |
The power-opening door refrigerator! (It was not plugged in when she did the commercial live...see YouTube for the video)
CLICK HERE TO GO TO moparwash's LINK This post was last edited 04/03/2015 at 19:43 |
Post# 817338 , Reply# 4   4/3/2015 at 19:26 (3,304 days old) by moparwash (Pittsburgh,PA )   |   | |
Post# 817340 , Reply# 5   4/3/2015 at 19:28 (3,304 days old) by moparwash (Pittsburgh,PA )   |   | |
Post# 817342 , Reply# 6   4/3/2015 at 19:30 (3,304 days old) by moparwash (Pittsburgh,PA )   |   | |
Post# 817344 , Reply# 7   4/3/2015 at 19:33 (3,304 days old) by moparwash (Pittsburgh,PA )   |   | |
Post# 817345 , Reply# 8   4/3/2015 at 19:34 (3,304 days old) by moparwash (Pittsburgh,PA )   |   | |
Post# 817346 , Reply# 9   4/3/2015 at 19:37 (3,304 days old) by moparwash (Pittsburgh,PA )   |   | |
Post# 817347 , Reply# 10   4/3/2015 at 19:40 (3,304 days old) by moparwash (Pittsburgh,PA )   |   | |
Again, thanks to Jeff for letting me see his amazing collection!...(I should of brought my pink set for a group shot)I wish I would of taken more pictures!..hope everyone liked the show!
This post was last edited 04/03/2015 at 20:02 |
Post# 817401 , Reply# 11   4/4/2015 at 04:52 (3,303 days old) by Gpevas (Parma Heights Ohio )   |   | |
Post# 817408 , Reply# 12   4/4/2015 at 06:47 (3,303 days old) by Jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Post# 817411 , Reply# 13   4/4/2015 at 07:40 (3,303 days old) by turquoisedude (.)   |   | |
Post# 817451 , Reply# 14   4/4/2015 at 14:03 (3,303 days old) by cadman (Cedar Falls, IA)   |   | |
Post# 817547 , Reply# 16   4/5/2015 at 06:15 (3,302 days old) by Jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
odd place to develop a leak. It must have been a factory fault on the weld lines. Those tubs usually have a heavy coat of enamel inside and out. My '57 was used to death, the grandmother went blind and could only use that machine because she knew the controls from memory so the grandson kept replacing the bearings , I think he said he did it 3 times since the 70's. That's a lot of washing. And now it needs new bearings again. But the tub and enamel looks fine. Well fortunate for you these slant fronts keep popping up like Maytags, they are survivors, you'll find a parts donor.
Post# 817570 , Reply# 17   4/5/2015 at 09:47 (3,302 days old) by Combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Hi Jed, I would love to see your collection sometime. Inlet valve for the 57 could be rebuilt unless the body is cracked also we have new water pumps for those if you need one.
The holes in the Outer tub were actually very common around weld points it's very hard to get porcelain enamel to adhear to the weld areas so this happens frequently, you can usually just fill the holes and seal them with epoxy or RTV silicone rubber. |
Post# 817590 , Reply# 18   4/5/2015 at 13:20 (3,302 days old) by ovrphil (N.Atlanta / Georgia )   |   | |
Post# 817641 , Reply# 19   4/5/2015 at 19:28 (3,302 days old) by philcoford (Maryland)   |   | |
Thanks for sharing, such great designs, interesting stories. Of course I love those pushbuttons. |
Post# 819749 , Reply# 21   4/17/2015 at 14:31 (3,290 days old) by brib68 (Central Connecticut)   |   | |
Post# 819780 , Reply# 22   4/17/2015 at 19:33 (3,290 days old) by norgeway (mocksville n c )   |   | |
You got those, That was a great find. |
