Thread Number: 59433
/ Tag: Vintage Dishwashers
KDS 17 leaky intake |
Post# 820325 , Reply# 1   4/21/2015 at 14:03 (3,286 days old) by chachp (North Little Rock, AR)   |   | |
Many of them will work for your machine but the most common one is 4171000. They are all over eBay. |
Post# 820359 , Reply# 2   4/21/2015 at 18:15 (3,285 days old) by eronie (Flushing Michigan)   |   | |
All the Energy Saver button does is cut the heat for the dry cycle. |
Post# 820679 , Reply# 4   4/23/2015 at 19:36 (3,283 days old) by quick-connect ()   |   | |
I'll order that fill valve promptly and report back once it's installed. |
Post# 821192 , Reply# 6   4/27/2015 at 18:15 (3,279 days old) by barcoboy (Canada)   |   | |
Post# 821202 , Reply# 8   4/27/2015 at 19:15 (3,279 days old) by barcoboy (Canada)   |   | |
Post# 821260 , Reply# 10   4/28/2015 at 06:22 (3,279 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
The black wire that goes to the new inlet valve should go to the black plastic over fill switch near the IV, also make sure that the other dark colored wire from the DWs wiring harness is still connected to the other terminal on the OFS. If this does not solve the filling problem check the OFS for continuity or just connect its to wires together as a test, these OFSs often failed. |
Post# 821268 , Reply# 11   4/28/2015 at 08:09 (3,279 days old) by quick-connect ()   |   | |
Thanks for taking the time to respond! What is the OFS ? (also, did I mention the fill valve is working now?) |
Post# 821270 , Reply# 12   4/28/2015 at 08:20 (3,279 days old) by chachp (North Little Rock, AR)   |   | |
Post# 821307 , Reply# 14   4/28/2015 at 14:04 (3,279 days old) by chachp (North Little Rock, AR)   |   | |
Post# 821313 , Reply# 15   4/28/2015 at 14:59 (3,278 days old) by barcoboy (Canada)   |   | |
