Thread Number: 59451  /  Tag: Wringer Washers
Restoring Rubber Rollers on Hoover 0307 Wringer
Post# 820531   4/23/2015 at 04:52 (3,284 days old) by Hooverpom69 ()
Hi All
I am in the process of restoring a Hoover 0307 wringer machine.
The rollers on the wringer aren't too bad, but they have started to crack. Can they be replaced?
If not, what is the best thing to do to preent further degredation?
Cheers
Stephen
Post# 820563 , Reply# 1   4/23/2015 at 08:39 (3,284 days old) by dnastrau (Lords Valley, PA)
Automotive rubber restorer; glycerine
You might try an automotive rubber trim and weatherseal restorer like the ones sold by companies such as Zymol, Wurth, Meguiar's, Eastwood, etc.
Another possibility is glycerine like you can buy at the drug store.
Soaking the rollers in any of these may work, but I would also be careful not to overdo it as you don't want them to be too soft, etc.
Andrew S.
Post# 820819 , Reply# 2   4/24/2015 at 21:19 (3,282 days old) by Hooverpom69 ()
Thanks Andrew
Post# 820859 , Reply# 3   4/25/2015 at 04:52 (3,282 days old) by Gpevas (Parma Heights Ohio )
Wringer rolls!
gpevas's profile picture
I have had good luck with sanding the rolls. I read in a booklet on wringer washers to use kerosene this works on all rubber rolls but you need to wash off after cleaning because it will rott the rubber if left on. I never needed to use kerosene but sanding worked for myself.
