Thread Number: 59478
/ Tag: Vintage Dishwashers
Kitchenaid KDS-20 Energy Saver V Superba by Hobart |
Post# 820777 , Reply# 1   4/24/2015 at 15:45 (3,260 days old) by eronie (Flushing Michigan)   |   | |
Please post pix! We can help you much better an faster if we can see what were dealing with!!! |
Post# 820781 , Reply# 2   4/24/2015 at 16:43 (3,260 days old) by theburnman ()   |   | |
ok sure, here's some pics. Even included the washer in all its glory to get your blood pumping :) |
Post# 820798 , Reply# 3   4/24/2015 at 19:35 (3,260 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
Post# 820802 , Reply# 4   4/24/2015 at 19:46 (3,260 days old) by theburnman ()   |   | |
they go into the corners (held in place with clips) to create a seal when the door shuts I guess , here is a picture of the left one still in place.
Post# 820807 , Reply# 5   4/24/2015 at 20:00 (3,260 days old) by rp2813 (Sannazay)   |   | |
Post# 820817 , Reply# 7   4/24/2015 at 21:08 (3,260 days old) by kb0nes (Burnsville, MN)   |   | |
Post# 820820 , Reply# 8   4/24/2015 at 21:26 (3,260 days old) by theburnman ()   |   | |
I wish that was the case unforuntaely I tried cycles with just water with same results. |
Post# 820868 , Reply# 9   4/25/2015 at 06:33 (3,260 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
These were there to stop lower corner door leaks, not all KA DWs had them, we always carried then on our truck and would add them to machines that wanted to leak in this area. I would imagine that you could cut some good rubber foam or closed cell type material and glue it in place to stop this leak. It may take a little experimenting to get it to work, if you take off the complete outer upper door panel assembly you should see a SS clip that held these corner gaskets in place, you should be able to reuse the SS clips to help hold new gaskets in place. |
Post# 820894 , Reply# 10   4/25/2015 at 13:19 (3,259 days old) by theburnman ()   |   | |
I'll give it a shot, thanks all. |
Post# 822013 , Reply# 11   5/4/2015 at 16:42 (3,250 days old) by bobbyderegis (Boston)   |   | |
Burnman, What side is it? I will be glad to send you a used corner seal. The manual describes their replacement. Looks like a pain in the neck. Bobby in Boston |
