Thread Number: 59517
Hoover spinarinse 3019 |
Post# 821177   4/27/2015 at 16:06 (3,257 days old) by sesteve (London, UK)   |   | |
I picked up this spin dryer for free recently along with 2 other appliances. Not sure I've seen one in the flesh with the white trim before but unfortunately if is beginning to disintegrate - think it's been damaged by sunlight. Not sure what to do to stop it getting worse.
Initially I though the drain hose was ok as it is really supple but it had a leak caused by the drain hose cracking near the base. I have a spare drain hose but the original hose has a tighter hook so I decided to cut off the damaged section and use the plastic one inside where it can't be seen. The fill hose however is pretty solid although it does soften with hot water. I've uploaded a video showing how fast this pumps out - same as a twinnie. Anyway, here are a few photos - not sure why I can't put them in order or get them the right way round.... S :) CLICK HERE TO GO TO sesteve's LINK |
Post# 821296 , Reply# 1   4/28/2015 at 12:44 (3,256 days old) by electron1100 (England)   |   | |
