Thread Number: 59530  /  Tag: Modern Automatic Washers
WM2277
Post# 821350   4/28/2015 at 20:09 (3,256 days old) by laundromat (Hilo, Hawaii)
laundromat's profile picture
A week ago, I loosely loaded a large load of wash in the LG front loading steam washer. Everything went fine. When they were finished,I noticed a stream of water coming out from the front base,right side. I didn't see any leaks so,I loaded a second set of wash. As the unit began to fill,more water came out. I pulled the washer from the wall,removed the backpanel and saw the pressure air hose dangling from the.case it was hooked onto. Evidently,the plastic male piece that is molded on to the switch broke off leaving the broken part.inside the air hose it was connected to.by a small metal clip. So, I'll be going on line to buy the new part.and replace it this weekend.
