Thread Number: 59652
Miele W/M pump....is mine faulty? |
Post# 822604   5/8/2015 at 18:05 (3,246 days old) by CandyD10_14X (London, United Kingdom)   |   | |
Hi all,
As you may know I own a Miele W562 Prestige Plus 6, I brought it in January 2009 and it has so far served me 6 years of sterling service. However, there is an issue which I cannot seem to resolve, all the Miele's I know make a famous 'chugging' sound with their pump when on a spin cycle, however my Miele fails to do this for some reason. I've had a look inside and cleaned out all the limescale I can, but even this doesn't work and it's something I'm beginning to miss on my machine and it really doesn't feel like a Miele anymore. I am aware another member on this site (AquaCycle) owns the same machine, but his one seems to pump normally. Is this the time to replace my pump or is there another solution? Please, I would appreciate all help, and I know it's not important, it's just I'm missing the sound it used to make when first delivered. Thank you so much, Brandon.
Post# 822605 , Reply# 1   5/8/2015 at 18:06 (3,246 days old) by CandyD10_14X (London, United Kingdom)   |   | |
Post# 822607 , Reply# 2   5/8/2015 at 18:47 (3,246 days old) by richnz (New Zealand)   |   | |
Is the machine faulty or are you trying to get the machine to make the chugging sound? |
Post# 822640 , Reply# 4   5/9/2015 at 04:38 (3,246 days old) by aegokocarat (United Kingdom)   |   | |
Our Miele doesn't make much of a chugging sound, nor does my grandmothers which is similar to yours, it must just be to do with them wearing in, I wouldn't worry too much Tom :) |
Post# 822688 , Reply# 5   5/9/2015 at 17:48 (3,245 days old) by CandyD10_14X (London, United Kingdom)   |   | |
Hi, no the machine is fine with removing the water, it just doesn't make the chugging sound anymore, I'm thinking of replacing the pump soon so that might do it good.
It just makes a steady humming sound as if it's full of water when it isn't. It's had a large build-up of limescale which I removed. I was trying to remove some limescale from the little hole on the right inside the filter, but I'm not sure how to. Maybe using some Calgon might help lol. Thanks. |
Post# 822704 , Reply# 6   5/9/2015 at 20:38 (3,245 days old) by logixx (Germany)   |   | |
Post# 822719 , Reply# 7   5/10/2015 at 01:48 (3,245 days old) by richnz (New Zealand)   |   | |
It looks to be set up in a kitchen from the photo. Does it connect under a sink? I wonder if the water cannot leave the drain hose fast enough to cause the chugging sound or if the non-return vent valve (and hose) may be gummed up. |
Post# 822762 , Reply# 8   5/10/2015 at 11:22 (3,245 days old) by CandyD10_14X (London, United Kingdom)   |   | |
