Thread Number: 59820
Maytag Neptune Advice |
Post# 824745   5/23/2015 at 08:05 (3,254 days old) by Newwave1 (Lincoln, United Kingdom)   |   | |
Hey gang!
I've finally joined the Maytag Neptune club for the crazy sum of 99p!!' Apparently if needs a new return valve? Can anyone tell me/show me what one of those is? Many thanks Darren
Post# 824793 , Reply# 1   5/23/2015 at 18:54 (3,254 days old) by Yogitunes (New Jersey)   |   | |
welcome to the world of Neptunes.....that's a touch panel version, internal heater and higher spin speeds....with Stain Brain!
but a return valve, you got me stumped on that one....can you get a bit more detail as to what its not doing, or what this valve should be doing.... the only thing I can think of as far as valves on these, is the solenoid inlet valves, and the set of solenoid valves that controls which dispenser needs water to dispense.... |
Post# 824831 , Reply# 2   5/24/2015 at 03:05 (3,254 days old) by Newwave1 (Lincoln, United Kingdom)   |   | |
Hey Yogi!
I'll ask the seller when I collect it tomorrow what the issue is. Return valve has me stumped lol! Ohh cool what spin is this then? I can't wait to get it. My long term plan is to replace the door with a windowed one from the commercial stack dryers! Darren
Post# 824833 , Reply# 3   5/24/2015 at 03:30 (3,254 days old) by foraloysius (Leeuwarden, Friesland, the Netherlands)   |   | |
Post# 824849 , Reply# 4   5/24/2015 at 09:04 (3,253 days old) by Yogitunes (New Jersey)   |   | |
Post# 824883 , Reply# 5   5/24/2015 at 11:55 (3,253 days old) by Newwave1 (Lincoln, United Kingdom)   |   | |
Post# 824896 , Reply# 6   5/24/2015 at 13:47 (3,253 days old) by foraloysius (Leeuwarden, Friesland, the Netherlands)   |   | |
Post# 824905 , Reply# 7   5/24/2015 at 15:43 (3,253 days old) by hoovermad (England)   |   | |
Did the seller also have the dryer for sale? I has brief dealings with him few weeks ago. |
Post# 824925 , Reply# 8   5/24/2015 at 17:57 (3,253 days old) by Yogitunes (New Jersey)   |   | |
Neptunes from the 3000/4000/5000/6500 series all spun at 1000rpm......that was their big claim to fame of that thousand speed spin......I have brochures here somewhere of when I bought one of the first ones...
the 7500 went the step further with the 1200.... I miss the JET sound of the 3000 taking off for spin....wish they still did that, but it was a matter of being silent..... |
Post# 824929 , Reply# 9   5/24/2015 at 18:21 (3,253 days old) by DADoES (TX, U.S. of A.)   |   | |
Service manual I have for MAH3000 dated May 1997 states max spin of 800 RPM +/-50 RPM (per "optimum" spin performance). Same is stated in a revision dated Nov 2003. Supplement dated Oct 2000 for MAH5500 and MAH7500 states LED model (5500) is 800 RPM +/-50 RPM. LCD model (7500) is 1000 RPM +/- 50 RPM. |
Post# 824931 , Reply# 10   5/24/2015 at 18:31 (3,253 days old) by foraloysius (Leeuwarden, Friesland, the Netherlands)   |   | |
Could you check that brochure? According to AJ Madison it's 1000rpm.
www.ajmadison.com/cgi-bin/ajmadis... |
Post# 825070 , Reply# 11   5/25/2015 at 11:57 (3,252 days old) by Newwave1 (Lincoln, United Kingdom)   |   | |
Hey guys,
I can confirm that the machine is a 1000rpm machine! It has a heater and lots of conversation cool features. It was a little grotty but nothing a little clean up wouldn't fix. Darren |
Post# 825072 , Reply# 12   5/25/2015 at 12:12 (3,252 days old) by henene4 (Heidenheim a.d. Brenz (Germany))   |   | |
Cool! It even has a coversed programming for the EU market, which really really makes me love the machine. What's the max temp you can select? |
Post# 825094 , Reply# 13   5/25/2015 at 15:50 (3,252 days old) by Newwave1 (Lincoln, United Kingdom)   |   | |
Post# 825101 , Reply# 14   5/25/2015 at 16:13 (3,252 days old) by foraloysius (Leeuwarden, Friesland, the Netherlands)   |   | |
Don't forget there is a stabilizer in the door, you might get balance issues faster if you put a door with a window in it.
Here's the link to the literature of the American model: www.maytag.com/-[MAH7500AWW]-1102... |
Post# 825399 , Reply# 15   5/27/2015 at 11:59 (3,250 days old) by Newwave1 (Lincoln, United Kingdom)   |   | |
My first proper wash in the Neptune.
Can anyone tell me how to disable the door lock to open the door and see the action until I get my door idea sorted? I've seen videos on them operating with the door open on YouTube! Darren |
Post# 825435 , Reply# 16   5/27/2015 at 17:33 (3,250 days old) by Yogitunes (New Jersey)   |   | |
you mean like this?......
this was a matter of finding another door, and either make a cut out like mine, or just the top portion with the section that goes into the latch and will hold the switch in so the machine will operate..... |
Post# 825473 , Reply# 17   5/28/2015 at 00:20 (3,250 days old) by Newwave1 (Lincoln, United Kingdom)   |   | |
Hey yogi!
I plan to do something very similar yes! I'm tracking down a door from one of the commercial stacks that you have on your dryer. I've put a link to a video of a members Neptune. He's holding the block in on the door that tells the machine that the door is closed but something must be wedged in to make the the machine think the door is shut? Thanks Darren CLICK HERE TO GO TO Newwave1's LINK |
Post# 825497 , Reply# 18   5/28/2015 at 06:16 (3,249 days old) by retro-man (- boston,ma)   |   | |
No he is just holding the button in with his thumb, while resting on the machine. That button tells the machine the door is closed and will operate that way. Jon |
Post# 825507 , Reply# 19   5/28/2015 at 07:24 (3,249 days old) by Newwave1 (Lincoln, United Kingdom)   |   | |
Post# 825513 , Reply# 20   5/28/2015 at 08:07 (3,249 days old) by Yogitunes (New Jersey)   |   | |
that's because the machine in the video is a 4000 series, only the button had to pushed in, on the Digital 5000 and up series, its a solenoid activated switch, and theres another sensor/switch to detect the actual door it closed....
you can bend and place a coat hanger to push in the plunger to simulate the door being closed, and then push in on the button.....but you do have to sit there the whole time and hold that button in.......note: you can't just let go, you have to press the pause button and wait for the door to unlock before removing that hanger and letting go of the button... |
Post# 825547 , Reply# 21   5/28/2015 at 14:47 (3,249 days old) by Newwave1 (Lincoln, United Kingdom)   |   | |
Post# 825754 , Reply# 22   5/30/2015 at 05:45 (3,247 days old) by Newwave1 (Lincoln, United Kingdom)   |   | |
Hey guys!
I filmed the rinse on the Neptune with the door open! I have damaged the door lock slightly in the process though! Enjoy Darren CLICK HERE TO GO TO Newwave1's LINK |
