Thread Number: 59942
Whirlpool HE Top-Load Washer |
Post# 826112 , Reply# 3   6/1/2015 at 16:51 (3,250 days old) by Tomturbomatic (Beltsville, MD)   |   | |
The only thing I can add to the above excellent tutorial is that this is not going to hold as much as it looks like it could to give best cleaning and rinsing results. Welcome to the other side. |
Post# 826123 , Reply# 4   6/1/2015 at 17:41 (3,250 days old) by murando531 (Augusta, Georgia - US)   |   | |
I agree with and second everything henene said above.
This washer is built on Whirlpool's VMW platform. While these machines are sometimes labeled as "Cabrio", they are very different from the true Cabrio/Oasis design, although they will look similar. The machines that JoeyPete and I have are true Oasis machines, with the Fisher&Paykel direct drive system and the separate recirculator pump. Instead, the VMW design uses a belt drive system, connected to a motor that oscillates in each direction to provide agitation. There is also a planetary gearbox that converts the torque from the motor and drive pulley into slower, more powerful strokes. For the spins, there is a "splutch" assembly that locks the agitator and basket together, also locking the transmission. While these machines look similar to their Oasis cousins as far as the basket and agitator, they behave very differently. The basket will turn in "pulses" as it fills to try and saturate the clothes completely, but there is no recirculation pump, so it's crucial to add detergent before the clothing so that it has time to dissolve properly. Like henene said, good performance with these machines is very reliant upon loading habits, so heavy fabrics need to be separated from light weight fabrics. Towels should be kept together, but you/she will find that they actually are the easiest to rollover while washing. Also, again, as henene stated, the Fabric Softener option should ALWAYS be left on, as it simply instructs the machine to do a deep agitated rinse rather than a spray rinse. The spray rinses in this type of washer are anything but effective because the fill flume isn't designed to spread across the load, and most of the water falls onto the agitator plate and goes under the clothes anyway. You'll also find that you should only need less than half of what you would usually need for a traditional top loader, even when using HE detergent. Use more consideration for the soil level than the actual load size or anticipated water level, because these washers usually won't fill more than to the top of the agitator anyway, even with larger loads. Like said above, the low water level is crucial for rollover; more water means the clothes float, and can't be "pushed" towards the center by the vanes. If she really wants to let the machine run open, the lid strike can be purchased on RepairClinic.com or other appliance parts sites for about ~$15. I bought one with my WTW4800 (a VMW but with a traditional agitator) and kept it on my wire shelving above the washer. It has a magnet in it so it's easy to keep up with. She can pop it in at the start just to make sure everything is going smoothly, and simply pause it, pop it out, and close the lid. |
