Thread Number: 59958
LG WaveForce - Full Cycle Videos |
Post# 826214   6/2/2015 at 09:54 (3,244 days old) by logixx (Germany)   |   | |
Found his channel the other day on YouTube.
"I don't know if this is how Sports Wear setting was designed to operate since these types of clothes are usually just sweaty and don't need much agitation, but I avoid this setting. Too much water is put in and no agitation occurs. Watch the orange shorts."
"Towels setting didn't produce any good results either, but I think the reason is some of the items I had in this load. Normally this setting rotates through the clothes good."
"Here's Bright Whites mode with a small load. Notice the 2 rinses."
"Here's the mode that stirs up so much hate because people think it doesn't use enough water. Notice the long 2-stage wash cycle followed by a brief spray rinse and a very long final spin."
"Bulky/Bedding Mode" |
Post# 826421 , Reply# 2   6/3/2015 at 07:26 (3,243 days old) by joeypete (Concord, NH)   |   | |
Post# 826450 , Reply# 3   6/3/2015 at 11:06 (3,243 days old) by georgect (Fairfield, CT)   |   | |
I just fail to see how the clothes on the top get clean with no turn over.
+ I can understand if the clothes were submerged and free flowing through waves of water but that's not the case. My opinion top loaders just can't be "HE" washers. Top loaders with traditional center agitator or wash plate with LOTS of water work better and faster. Front loaders (I feel) can only truly be high efficiency. |
Post# 826457 , Reply# 4   6/3/2015 at 11:45 (3,243 days old) by henene4 (Heidenheim a.d. Brenz (Germany))   |   | |
Am I getting something wrong, or did you just not watch the Whites & Cotton\Normal videos? I mean, especially in that time laps version, one can clearly see the 2 colored items in the white load diappearing and reappearing several times. After the last WaveForce action, the load on normal moves pretty good as well. |
Post# 826465 , Reply# 5   6/3/2015 at 13:48 (3,243 days old) by mark_wpduet (Lexington KY)   |   | |
Post# 826516 , Reply# 6   6/3/2015 at 20:15 (3,243 days old) by logixx (Germany)   |   | |
I don't know... These HE top loaders with those very flat disks (Samsung and LG) look more like electric buckets to me: they fill with water/detergent, jiggle and soak the clothes for some time and then spin. Except for the spinning that's nothing a gaint bucket could't do either. The only loads that really moved around were those with the water almost up to the top of the load - just like in a traditional top loader. I think the washers with taller impellers like F&P or the previous Cabrios did better with a low water level than their Asian counterparts.
The only thing in favor of the LG I can say is that he probably didn't load the washer in the best way. Items were already looking tangled before the cycle even began. He must have dumped them straight in. |
Post# 826686 , Reply# 7   6/5/2015 at 06:12 (3,241 days old) by mark_wpduet (Lexington KY)   |   | |
The new Cabrio/Bravo's look cool. I like the LG waveforce too, but I think at the end of the day, I would feel more comfortable with a front load washer with heater and cycles that use more water. That said, I don't think these are bad machines at all, unless you try to wash a comforter in them, then forgetaboutit! - at least from the vids I've seen.
Post# 826697 , Reply# 8   6/5/2015 at 07:21 (3,241 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
The time lapse videos are little more than entertaining and a bit nausea-inducing to watch after minute or two.
I know several people who own these top loading, wash-plate machines and all are dissatisfied in one way or another with the performance. Some of the complaints are undissolved powder detergent, even when using the dispenser; moderate to severe tangling especially with larger items; lint left on clothes; generally poor cleaning. One or two are LG/GE, the other a newer Samsung. Most attribute their problems to lack of sufficient water. "I want my old washer back" is a common refrain. I think the whole "can I wash my king sized comforter in it?" trend started with the advent of front-loading marketing methods and the general association of front-loading washers with those at the local laundromat ranging in size from 30-50lb capacities. Slogans like "if you can get it in the machine, it will get it clean." and the outright blatant "king sized capacity" moniker doesn't help. Unless you have only a need to get the item wet, I would not consider anything that cannot move up, down and around the basket of the washer "clean". Jiggling back and forth and a little spinning isn't going to remove lint, hair, etc. from the fabric but I guess we've relegated that responsibility to the dryer and the vacuum cleaner once the item is removed and shook out after the laundry process is completed. Anyone with small children or pets will readily admit that sometimes comforters and bedding need to be cleaned a little more than just wetting and drying. I have been tempted with the LG front-control models as I think the look is cool, but I can't get past the limitations so I guess I'll keep watching the free videos and doing my own laundry in a vintage top loader or my modern front-load machines. |
Post# 826700 , Reply# 10   6/5/2015 at 07:51 (3,241 days old) by joeypete (Concord, NH)   |   | |
Those LG/Kenmore machines all have the "WaterPlus" feature that adds more water to any cycle. I think these machines do definitely work better with more water. They remind me a lot of the portable machines with pulsators that actually are not considered HE at all. They fill right up with water and clean fine. The videos I've seen of these LG's with full water, DO clean very well. But that's the trick.
The F&P/WP Cabrio design machines (with the recirculating water) are a whole other story. They manage to clean MUCH better using low water. But they make use of the larger impeller to get the clothes clean. I'm not terribly impressed with the new Cabrio design. I'm actually glad I didn't buy it and stuck with the older design. |
