Thread Number: 60355
Old Belt Drive ,Standard Direct Drive and New VMW Washers |
Post# 830181 , Reply# 1   6/30/2015 at 16:06 (3,194 days old) by LordKenmore (The Laundry Room)   |   | |
I've only used the old BD (Belt Drive) and DD (Direct Drivie) designs.
In operation, the big differences I note: -During agitation, BD tends to make "woo woo" sound, DD makes a "chugga chugga" sound. -BD machines don't pause the motor as much. At the end of wash/deep rinse, the motor stays running, and the machine immediately goes into drain, then from drain goes immediately to spin. DD pauses after wash/deep rinse. Then starts the drain. On my current specimen, there is another pause after drain, then it goes into spin. -Agitation is gentler in a BD, much sharper/more abrupt looking in a DD. -BD I remember would do multiple spray rinses. It seems like that vanished in the direct drive era. -DD is far more likely to destroy/wear clothing, at least from hearsay. My limited experience suggests that there is truth to this allegation. -BD had for a period pretty washer colors like turquoise. |
Post# 830191 , Reply# 2   6/30/2015 at 17:15 (3,194 days old) by DADoES (TX, U.S. of A.)   |   | |
Large mechanical differences. (Hopefully this info is valid.) Vintage belt drive does not use a reversing motor. Most models through the years utilized a recirculating lint filter, either manual clean or self-cleaning. The spin safety lid switch disengaged spin via the wigwag but did not shut off the drive motor or timer. The pump is driven mechanically by the belt. Majority of the machines through the years had a porcelain outer tub (there was an experimentation with plastic). The tub & transmission & motor mounted to a baseplate which was suspended from three support rods anchored at top of the cabinet. Service access was through a small rear panel, from beneath the machine, and by raising the cabinet top. Direct drive motor reverses for agitation vs. spin & drain (which is the reason for the pauses). A recirculating lint filter was never utilized but a couple models did recirculate for other functions (Resource Saver for rinsing and Catalyst for detergent treatment). Early models did a spin-drain. The lid switch did shut off the drive motor & timer during spin (& drain). The pump is driven mechanically by direct attachment to one of the motor's two shafts. All models had plastic outer tubs. The tub sat atop a pedestal and anchored with springs, the transmission mounted beneath, and the motor mounted to the transmission. The outer cabinet (top/front/sides as a unit) removed for service access, with the transmission removable from beneath. VMW units are belt drive. The motor reverses forward and back continually during agitation. Pulsing the power current varies the speed. The motor reversing provides oscillating action to the agitator, not the transmission as with the other two designs. The transmission is a planetary gear mechanism and functions for agitation RPM reduction and torque increase. The agitator (or impeller) is always driven when the motor & transmission pulley rotate. A splutch (spring-clutch) mechanism operated by a shift actuator (which also functions as a speed sensor) engages/disengages basket spin from drive teeth on the transmission pulley. There is no spin brake (BD and DD do have a brake). The lid locks during spin (the entire cycle on early models but I understand that was changed later?). The pump is a separate electric unit from the main drive motor. The tub is suspended via four rods anchored at the four corners of the cabinet. The motor, transmission, & pump mount to bottom of the tub. Service is by raising the top and from beneath. |
Post# 830196 , Reply# 3   6/30/2015 at 18:43 (3,194 days old) by norgeway (mocksville n c )   |   | |
IMHO ..of course is the belt drive washes....the DD THRASHES!!! the DD tub is awkward because its deep and narrow,the belt drive is to my mind the best all around washer ever. |
Post# 830240 , Reply# 5   7/1/2015 at 05:51 (3,194 days old) by arbilab (Ft Worth TX (Ridglea))   |   | |
Post# 830323 , Reply# 6   7/1/2015 at 14:58 (3,193 days old) by LordKenmore (The Laundry Room)   |   | |
>If you're used to servicing legacy Maytags, get your thesaurus of obscenities out when you have to change the belt on a wigwag.
I remember looking into trying that once, and frankly felt overwhelmed by the prospect, as I studied the washer in question. A neighbor did the property maintenance here on this property when I first lived here. He was pretty good with mechanical stuff--even did his own work on his cars once. One time he was called to change a Kenmore belt, and it was apparently a total nightmare. He ended up putting the washer on its back IIRC to get at the belt...and ended up losing a huge amount of oil. So much oil that I think they ended up discarding the machine. (That is, the machine was dumped, although no idea whether it failed due to loss of oil, they decided "we won't bother trying", or some other problem cropped up.) When I was having trouble with a Kenmore, he came, took one look, and basically said: "One of those wig wag monsters!" |
Post# 830326 , Reply# 7   7/1/2015 at 15:12 (3,193 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 830327 , Reply# 8   7/1/2015 at 15:21 (3,193 days old) by LordKenmore (The Laundry Room)   |   | |
I have to admit I have very mixed feelings about those BD machines. I have a certain weakness for them (it is not an accident that my name here is Lord KENMORE...and no, I'm not referring to Kenmore stoves, refrigerators, freezers, or dryers). When I first lived here, there was an old BD Kenmore, and it was fun having it around and "experiencing" the Kenmore washer experience again. (Funny thing, but I'd used a BD Whirlpool a year or so previously at the place I lived then, and yet it didn't evoke that same sense, even though the basic system was the same.)
Sometimes, I think I'd like to own my own BD machine. BUT...I have real concerns about the difficulty of servicing those machines. As I mentioned above, I once looked at doing a belt change, and frankly found the prospect overwhelming: it's almost as if Whirlpool went out of their way to make it as hard as possible to change that dratted belt. I am also not impressed by the difficulty of getting inside to work on the machines--that access panel seems like it would be "enough" until you actually have it off, and are staring into the inner workings of the washer. As someone with limited repair experience, and limited confidence, I honestly have to wonder if I'd be able to do much if something went wrong on my own machine. I have to wonder how much it would cost to get someone to do what I can't do. Meanwhile, there are a lot of things I don't like about DD machines. Some is personal--I used a DD machine during a period I'd like to forget. They are not as good as BD for washing ability. Then there is that whole Shredmore thing. I can't chime in on that definitively at this point from my own experience, but so many AW.org people have had trouble that I have to say there must be some issue. AW.org are not laundry idiots--they are NOT people who will stuff the tub so completely that the only way to close the lid on the washer is weighting down with a concrete block. BUT...these flaws to one side, one thing that does seem appealing is that it appears that servicing is easier. |
Post# 830328 , Reply# 9   7/1/2015 at 15:24 (3,193 days old) by LordKenmore (The Laundry Room)   |   | |
>It's a challenge and takes some time but is doable once the procedure is understood and one has gone through it a time or two.
I imagine so. As I think of it more, one issue I recall was that I had no luck turning up info on the procedure. There are video clips for other repairs, but at least at the time I looked into doing it, I had no luck finding a WP belt change clip. |
Post# 830329 , Reply# 10   7/1/2015 at 15:30 (3,193 days old) by LordKenmore (The Laundry Room)   |   | |
Post# 830352 , Reply# 13   7/1/2015 at 18:22 (3,193 days old) by LordKenmore (The Laundry Room)   |   | |
Post# 830382 , Reply# 14   7/1/2015 at 21:07 (3,193 days old) by washerlover (The Big Island, Hawai’i)   |   | |
I, too, am very afraid of replacing belts on Kenmores and Whirlpools -- mine are doing okay now but I dread the day I'm going to have to face the music and try to do the job. Maytags and Norge/Wards are so much easier!
And I have to agree with the consensus of this thread -- DD machines are no good. Rough on fabrics and not great turnover. |
Post# 830389 , Reply# 15   7/1/2015 at 22:14 (3,193 days old) by murando531 (Augusta, Georgia - US)   |   | |
The only good DD was the KitchenAid. 120 strokes per minute versus the WP/KM 180 spm. The larger fins created strong currents that moved even large loads around more fluidly, which means the fabrics spent less time being beaten by the chaotic agitation of the WP version. The motor's slower speed during agitation may have also extended the life of itself and the transmission as well.
I'd give anything to have the one we had when I was growing up. I was a kid so I didn't have the authority to ask my parents to keep it so I could try to fix it, but today I'm confident that it was a simple coupling replacement. A good machine gone to waste. The Maytag Atlantis that replaced it was and still is a phenomenal machine, but I wouldn't have traded that KA for anything in the world. |
Post# 830425 , Reply# 17   7/2/2015 at 06:35 (3,193 days old) by arbilab (Ft Worth TX (Ridglea))   |   | |
When I did that KM belt there was no such thing as internet videos. But I'd been taking lawnmowers apart since I was 12 and fixing slant Westys even longer. How hard could it be?
Well it went right back together and back into service good as new. Maybe I'm just better at expletives than the average person. The lord's name is not in vain when it gets you where you're going. |
Post# 830427 , Reply# 18   7/2/2015 at 07:10 (3,193 days old) by kenwashesmonday (Carlstadt, NJ)   |   | |
I remember the first time I changed a belt on a Whirlpool/Kenmore belt drive machine, let's just say I did it the hard way. The next time I did one the bag had instructions on it and it wasn't nearly as bad. Ken D. |
Post# 830443 , Reply# 19   7/2/2015 at 09:23 (3,193 days old) by Yogitunes (New Jersey)   |   | |
I give anyone an "A" for effort, of even attempting to repair or replace a belt.....it may or may not work, but you gave it your best shot....that's all anyone can ask.....
I was raised, you didn't use it unless you knew how to fix it, how to take care of it, and/or how it operated.....washer, dryer, lawnmower, car, etc.!.... most want to just throw clothes in and turn a switch.....but run when something goes wrong!.... your never too old to learn something new.... if the odd chance that you need to call someone to fix something that your not familiar with.....you better be there watching closely, so you don't have to call him again.....and ask questions!....plus offer him something to drink, it can go a long way.... |
Post# 830494 , Reply# 20   7/2/2015 at 15:09 (3,192 days old) by twintubdexter (Palm Springs)   |   | |
Good advice, just make sure you don't try to help with the repair. Service people usually hate that. Lots of times I went out on a service call along with the technician in case some heavy appliance had to be moved or taken into the shop and saw many instances of "customer interference." Most times I just stood their and watched. It was a great job for a teenager to have especially since the return trip often meant a stop at the doughnut shop. My dad was the manager and I was sworn to secrecy. |
