Thread Number: 60399
Neptune help |
Post# 830551   7/3/2015 at 02:44 (3,219 days old) by Newwave1 (Lincoln, United Kingdom)   |   | |
Guys,
If you own a Neptune could you take a photo of the door hinges and how they fit to the door as I took mine off weeks ago to reverse the door and I can't get it to fit properly! Many thanks Darren
Post# 830575 , Reply# 1   7/3/2015 at 08:57 (3,219 days old) by Yogitunes (New Jersey)   |   | |
for the most part, its an easy job, but there are times the slots don't line up with the plastic shroud and the front cover....sometimes you have to attach the hinges first, then attach the door.....
with the front off as you have it, trying installing the door, or at least the hinges, to see if something might be in your way..... you can put the door on first, close the door, then install the front cover....then open the door and install the screws.... seems like you got a fighter there on your hands.... |
Post# 830897 , Reply# 2   7/5/2015 at 19:10 (3,216 days old) by stinkerb06 (Modesto, CA)   |   | |
