Thread Number: 60541
/ Tag: Wringer Washers
How do I fix this? Brainstorm with me please... |
Post# 831966 , Reply# 1   7/12/2015 at 11:47 (3,182 days old) by Yogitunes (New Jersey)   |   | |
Post# 832218 , Reply# 3   7/14/2015 at 07:50 (3,181 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
There is a locking pawl that is supposed to keep the wringer from swing around violently if it jams under load, I would suggest you inspect and repair this part as it can be a little dangerous if you are hit by the wringer assembly when it starts swinging.
The pump drive pulley is a tough thing to make a lasting repair on, if you can not find a good used or new water pump I would consider installing an electric drain pump on the washer.
Post# 832219 , Reply# 4   7/14/2015 at 08:25 (3,181 days old) by Maytagbear (N.E. Ohio)   |   | |
is Lehman's Hardware, in Kidron, Ohio. Link is to the home page, not the wringer page. Lawrence/Maytagbear CLICK HERE TO GO TO Maytagbear's LINK |
Post# 832232 , Reply# 5   7/14/2015 at 11:39 (3,180 days old) by alr2903 (TN)   |   | |
CLICK HERE TO GO TO alr2903's LINK on eBay |
