Thread Number: 60912
insulating a speed queen washer |
Post# 835690 , Reply# 1   8/8/2015 at 13:39 (3,183 days old) by Frigilux (The Minnesota Prairie)   |   | |
The only solution is for the components not to make those sounds in the first place. Insulating the cabinet won't really help and I strongly suggest you don't put insulation around any components.
If owning an old-school, traditional toploader is what you want, it's probably best to just learn to live with the sounds the machine makes. |
Post# 836638 , Reply# 4   8/14/2015 at 15:52 (3,176 days old) by washman (o)   |   | |
is music to my ears. Well, when I'm not listening to Kiss Alive II anyway! |
Post# 836905 , Reply# 5   8/16/2015 at 09:08 (3,175 days old) by Yogitunes (New Jersey)   |   | |
Post# 836907 , Reply# 6   8/16/2015 at 09:57 (3,175 days old) by esty (New Jersey)   |   | |
Thank you all for your suggestions. Where should I put the insulation? Should I tape it up on the inside of the cabinet? I'll try sliding some insulation under the washer also. That's an easy fix idea. Thanks! |
Post# 836909 , Reply# 7   8/16/2015 at 10:36 (3,175 days old) by logixx (Germany)   |   | |
