Thread Number: 60923
/ Tag: Vintage Dishwashers
Can a KDS-37 SST be made into an undercounter model easily? |
Post# 835447 , Reply# 1   8/6/2015 at 19:44 (3,156 days old) by bigalsf (Salt Lake City)   |   | |
Yes. You just need to remove the side panel (4-6 Phillips head screws) and then install the machine as normal. It has the same plumbing and electric connections as the KDS 17 (the model it's based on). Good luck! Great machine; you'll love it! |
Post# 835573 , Reply# 2   8/7/2015 at 13:41 (3,156 days old) by chachp (North Little Rock, AR)   |   | |
You could install it without taking off the panel if you wanted to. If just depends on which side your connections will feed through. Leaving the panel on may provide a little extra sound proofing and insulation although I prefer using a roll of the wrap they make for water heaters. It's a foil like material on one side and the insulation on the other. Works really well for sound and heat. |
