Thread Number: 60974  /  Tag: Vintage Automatic Washers
Maytag A612 Problems
Post# 835917   8/10/2015 at 13:51 (3,175 days old) by thesnail (PA)
My Maytag A612 will not run, and the motor emits a loud buzz.
Turning it off, and moving the belt by hand a few inches starts it again. Yesterday, it stopped completely.
I swapped it out with another Maytag I had on hand, and opened the case to look at it today. During the move, a few of the wires appear to have fallen off the start switch. Do I just match the wires from the washer to the start switch and then to the motor by color?
If not, can someone provide a photo of the correct wiring?
Also, what is the correct method of testing these motors?
The tag on the back of the controls reads:
Model A612
Series 02
Serial 033363 PP
Any help is very much appreciated!
Post# 835952 , Reply# 1   8/10/2015 at 17:25 (3,174 days old) by goatfarmer (South Bend, home of Champions)
goatfarmer's profile picture
Wires should be color coded. There should be a wiring diagram, if not on the front of the tub, on the inside of the console.
Post# 836106 , Reply# 2   8/11/2015 at 12:21 (3,174 days old) by thesnail (PA)
So I should just match the colors on both the console and motor wires?
What about the unlabeled pins?
Can someone please provide a photo of the wiring on one of these.
I found the schematic, but can't make heads or tails of it.
The switch is part # 207684
Attached is a photo of the switch.
Any help is much appreciated!
