Thread Number: 61104
/ Tag: Modern Dryers
Speed Queen Dryer Question |
Post# 837381   8/19/2015 at 19:31 (3,170 days old) by stricklybojack (South Hams Devon UK)   |   | |
Post# 837392 , Reply# 1   8/19/2015 at 20:20 (3,170 days old) by washman (o)   |   | |
plug ok. The 4th wire is for new construction or renovation that requires a ground thru neutral as I found out when I moved in my new home April this year. |
Post# 837396 , Reply# 2   8/19/2015 at 20:47 (3,170 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Your connections are fine, The green wires are very important and are in the correct positions.
Be very sure that the three screws are good and tight, I can't really tell from your picture, but if that is a used power cord and if there is any discoloration where the eyelets are crimped to the copper wire, go get a NEW cord.
Question, why do you have an electric dryer in Southern California. |
Post# 837398 , Reply# 3   8/19/2015 at 20:55 (3,170 days old) by Stricklybojack (South Hams Devon UK)   |   | |
being located on the coast, it is often foggy and damp. My mother uses the cloths line a lot, but usually in conjuntion with the dryer. So she ends up using the dryer regardless of weather. I remember when i was a child in this same house my brother using the dryer (a Fridgidaire paired with a 118 washer) to warm his wet suit before surfing in the winter. |
