Thread Number: 61157
How to remove the tub/replace snubber on old 70s Speed Queen |
Post# 837947 , Reply# 1   8/23/2015 at 22:53 (3,166 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
What is the problem you are trying to fix? Spinning tub while agitating?
It's rare that you would need to do more than clean the snubber plates and adjust the snubber springs if you're having trouble with balancing issues or trying to center the spin tub. You're on the right track to remove the tub, but you'll need to remove the agitator post before the spin tub will come out. There is a thrust collar below the spin pulley in the mechanism. Depending on the exact problem you're trying to fix, you may not need to remove the tub at all. |
