Thread Number: 61177
Pink 1959 Frigidaire Custom Imperial set |
Post# 838269 , Reply# 1   8/25/2015 at 20:02 (3,160 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
Post# 838279 , Reply# 2   8/25/2015 at 21:39 (3,159 days old) by Frigilux (The Minnesota Prairie)   |   | |
Post# 838309 , Reply# 3   8/26/2015 at 06:53 (3,159 days old) by Doug17 (Huntsville,Alabama)   |   | |
Post# 838310 , Reply# 4   8/26/2015 at 07:06 (3,159 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
The single most destructive thing to avoid is moisture, it is best to keep just about anything in low humidity as possible, anything close to 50% is fine. Also avoid sunlight and excessive heat, freezing will not hurt at all as long as the washers pump and inlet valves are drained [ on this washer all you have to do is remove the drain and inlet hoses] if fact if you could keep the machine frozen all the time it would last longer.
If the machines are to be stored in a dusty area or an area where the humidity varies from time to time it would be best to completely wrap them in stretch plastic, good luck with these cool machines, I hope you get to use or play with them soon.
Post# 838314 , Reply# 5   8/26/2015 at 07:30 (3,159 days old) by turquoisedude (.)   |   | |
Wow! Congratulations on an outstanding score! They are in wonderful condition and I hope you get to use them soon. I am thrilled to have recently acquired a turquoise version of the 1959 washer myself.
In case you ever need them, the service and user manuals for both the washer and dryer are available here on this site in the 'Manuals and Literature' section.
The link below is the service manual, but you'll be able to find them all in that section.
Good luck with them! CLICK HERE TO GO TO turquoisedude's LINK |
Post# 838319 , Reply# 6   8/26/2015 at 07:45 (3,159 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
