Thread Number: 61208
/ Tag: Wringer Washers
Needed: RCA Whirlpool Worm Shaft Seal |
Post# 838665 , Reply# 1   8/29/2015 at 17:17 (3,133 days old) by Tomturbomatic (Beltsville, MD)   |   | |
You might check with Modern Parts in Parma, Ohio. |
Post# 838699 , Reply# 2   8/30/2015 at 09:40 (3,133 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
First I would look up the WP part # if you are searching appliance companies that might have an orignal part in their stock.
I would also check with companies that specialize in oil seals etc, the old oil seal # you have might help them and last you may have to measure the shaft and opening the seal is pressed into and find something that fits.
I think that you will find something that works.
Post# 838761 , Reply# 3   8/30/2015 at 20:03 (3,132 days old) by Bobbi (Pennsylvania)   |   | |
Thank you for the replies. For now, we've heated the seal in boiling water and reshaped it. So far, so good. That should hold us over until a replacement is found. |
Post# 838773 , Reply# 4   8/30/2015 at 22:05 (3,132 days old) by kb0nes (Burnsville, MN)   |   | |
As John mentioned above, if you can't find an original part most any typical shaft seal should work fine. In many cases the factory part is just a common off the shelf part anyhow.
If you can measure the shaft diameter and the bore it fits in most any bearing shop should be able to fit a common size. McMaster Carr has a number of sizes you can peruse here: www.mcmaster.com/#rotary-seals/=y... Perhaps you will see something familiar there! |
