Thread Number: 61521
/ Tag: Twin-Tub Washers
Servis MK 2 twin tub , tripping electric |
Post# 841896 , Reply# 1   9/20/2015 at 09:12 (3,140 days old) by cuffs054 (MONTICELLO, GA)   |   | |
Lance, perhaps it's not the machine but the power supply. Is he overloading it? |
Post# 841967 , Reply# 2   9/20/2015 at 17:12 (3,139 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
Hi Lance , good to catch up earlier, if Gary is reading this "Welcome" to the club, a few questions would be..
Is the spinner tripping when its run Dry or when water is present? If with water is it when pumping sudsy water out from transferring water from washtub to spinner? or when using the rinse nozzle for flow rinsing? It could be water running over the top seal bellows and dripping on the electrics and / or motor.... or water spraying from a leak underneath, pump / seal or outlets pipe. I would suggest unplugging from mains, taking the back off and to see if any leaks / wet patches present, if its a slow drip might be work taping some rigid plastic covering over the motor or electrical loom to avoid the tripping... The thin flexipipe from the spinner inlet nozzle to the spin can rinse nozzle (runs under the washdeck) can split apart when using with high pressure mains water, have done this myself and it did drip water onto the motor tripping the electrics on mine, I just avoided using the flow rinse and hosed the rinse water straight into the spin tub... Let us know how you get on Gary!! |
