Thread Number: 61608
/ Tag: Classified Ad Finds
Vintage KDA-5 Portable Dishwasher - $50 (berkeley north / hills) |
Post# 842717   9/25/2015 at 10:31 (3,128 days old) by ovrphil (N.Atlanta / Georgia )   |   | |
Post# 842748 , Reply# 1   9/25/2015 at 14:06 (3,128 days old) by bajaespuma (Connecticut)   |   | |
Post# 842779 , Reply# 2   9/25/2015 at 18:20 (3,128 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Post# 842837 , Reply# 3   9/26/2015 at 03:48 (3,128 days old) by chachp (North Little Rock, AR)   |   | |
with a Mobile Maid that hid under the counter like that. If I remember correctly that cubby probably would have accommodated a built-in. Seems that would be a pain in the butt to have to slide it all the way out every time you want to access the dishwasher. I am in and out of mine so many times a day that I'm afraid that would get old quickly. |
Post# 842845 , Reply# 4   9/26/2015 at 07:06 (3,128 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
You wonder why top loading dishwashers vanished never to make a return. Well there are many reasons but the main annoyance to my mind is having to take things off the top each time to get at the insides.
Suppose if one can manage without using the thing as extra counter or other space it would be fine. However I keep my Maxim convection oven on top of the MM. It sat on top of the Frigidaire dw before it and have no use for something that cannot perform double duty as it were. So yes, each time one wants to load or unload the MM everything on top must come off then are put back when done. I solve this by really loading after meals. It is enough to make you weep after doing all of that to find a plate or glass left. On balance top loading dishwashers aren't that convenient IMHO, especially if one is living in tight quarters. If and when a front loading portable like a good Kitchenaid comes my way.... Being as all this may having cubby is probably the best alternative. At least then all one must do is pull the unit out to load or unload. |
Post# 842883 , Reply# 6   9/26/2015 at 13:00 (3,127 days old) by rp2813 (Sannazay)   |   | |
After we got our first dishwasher, the uber BOL 1970 Frignature toploader, the only space where it could live was next to the stove across the kitchen from the sink.
When my dad did a DIY replacement of the tile counter tops, he also removed a set of drawers that were adjacent to the sink and moved them to the space next to the stove. The Frignature moved to where the drawers were, in the opening that was created under the new counter top. Yes, it had to be rolled out for loading, but since it was a cheap model it had the hoses up front, so if desired it could be rolled back into place before running it.
What my dad didn't do was consider the height of the counters, and when the first built-in machine was installed, it had to be on skids made of 2x4s to close a large gap between the machine and counter top. Every dishwasher since has required these spacers. Only the Thundering Thermador was a little different, requiring 1x4s instead. |
Post# 842897 , Reply# 7   9/26/2015 at 16:37 (3,127 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Post# 842938 , Reply# 9   9/26/2015 at 20:09 (3,127 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
