Thread Number: 61669
/ Tag: Modern Dishwashers
Kitchenaid KUDM25SHBL1 Foaming and Leaking |
Post# 843220 , Reply# 2   9/28/2015 at 12:23 (3,130 days old) by ponchoguy (NYC Suburbs)   |   | |
I think she uses detergent tabs (no rinse aid liquid or anything like that), but I've been telling her first thing is to get rid of the suds first as ANY machine will leak suds... |
Post# 845299 , Reply# 3   10/11/2015 at 13:55 (3,117 days old) by Ponchoguy (NYC Suburbs)   |   | |
Still foaming....any ideas? Hasn't had soap in it for over a month. Did the salt trick and it ran with no leaks. Tried again, and foam as shown.... |
Post# 845310 , Reply# 5   10/11/2015 at 14:27 (3,117 days old) by cuffs054 (MONTICELLO, GA)   |   | |
I've got the same problem with my Whirlmore Ultra Wash II. I can hear the suds forming just after the dispenser drops the tab. DW doesn't do it with powder. I'm blaming it on the mighty power of the pump! |
Post# 845361 , Reply# 6   10/11/2015 at 20:13 (3,116 days old) by Combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
I think she got some hand dishwashing soap in the machine, it can take a long time to clear this out whenever we have a customer who's machine starts foaming we advise them to stop the dishwasher and add 1/4 cup of cooking oil, salt and vinegar do nothing.
Detergent tablets contain wedding agent and can contribute to foaming problems Low fill level could also cause foaming. It's also possible that the check valve at the drain on the pump is worn out and this allows air to be drawn back into the pump which contributes to the dishwasher making a lot of foam the check valve may need to be replaced. You can often tell if the check valve is bad by listening at the disposer or airgap While the dishwasher is washing and if you hear is sucking noise you know the airgap is shot. |
Post# 845421 , Reply# 7   10/12/2015 at 09:16 (3,116 days old) by pierreandreply4 (St-Bruno de montarville (province of quebec) canada)   |   | |
is the kitchen aid dishwasher an he and filter model no grinder i have a kenmore elite dishwasher when purchuise in 2005 the sears clerck told us it was a kitchenaid base model sometime you need to purge the extra water with the cancel drain button and if the person use say cascade tabs those contain some dawn liquid soap or if she puts more than 1 tab that can cause suds i do not know
Post# 845736 , Reply# 8   10/14/2015 at 00:55 (3,114 days old) by askolover (South of Nash Vegas, TN)   |   | |
In my old Maytag we had foaming with Finish and Cascade. Now that the KA is installed, I've been using gel with chlorine and it's been washing fine. This morning and tonight I used a Walmart brand powder packet and I could hear the foam, opened the door and sure enough there it was. A few days ago I noticed foaming with Finish in the KA too. I guess I'll just stick with chlorine gel that was out when this KA was built...worked fine for all those years before enzymes! |
Post# 845746 , Reply# 9   10/14/2015 at 04:17 (3,114 days old) by Chachp (North Little Rock, AR)   |   | |
Post# 846563 , Reply# 11   10/19/2015 at 09:18 (3,109 days old) by ponchoguy (NYC Suburbs)   |   | |
So far, so good...fingers crossed....Thanks for all the input. |
Post# 846564 , Reply# 12   10/19/2015 at 09:28 (3,109 days old) by chachp (North Little Rock, AR)   |   | |
Post# 847197 , Reply# 14   10/23/2015 at 13:03 (3,105 days old) by ponchoguy (NYC Suburbs)   |   | |
Anyone have a good source for this lower rack? As you can see from the photo, it's seen better days. It's expensive new and if I could find a good used one, that would work. It's part #3381480 originally which is now superseded to W10134647. Thanks... |
Post# 849243 , Reply# 15   11/2/2015 at 08:32 (3,095 days old) by ponchoguy (NYC Suburbs)   |   | |
Bump on a good lead for a reasonably priced lower rack... |
Post# 857302 , Reply# 16   12/18/2015 at 13:40 (3,049 days old) by ponchoguy (NYC Suburbs)   |   | |
Bump, anyone have a good lower rack? Thanks... |
Post# 882308 , Reply# 18   5/26/2016 at 20:59 (2,888 days old) by ponchoguy (NYC Suburbs)   |   | |
Thanks, I'll check that out. Sorry for the late reply, lots going on, like everyone else :). |
Post# 921086 , Reply# 19   2/13/2017 at 08:52 (2,626 days old) by ponchoguy (NYC Suburbs)   |   | |
Thanks to all. I found a decent rack for $62 shipped via Ebay. I appreciate everyone's input! |
Post# 922806 , Reply# 20   2/21/2017 at 06:53 (2,618 days old) by ponchoguy (NYC Suburbs)   |   | |
The lower rack that was shipped was not right, so the search continues! Anyone out there with a good one, let me know. Thanks! |
Post# 924169 , Reply# 22   2/28/2017 at 11:29 (2,611 days old) by ponchoguy (NYC Suburbs)   |   | |
Steve: Sure, I will get the data from my sister and post it here for you. Thanks again.... Joe |
Post# 925021 , Reply# 26   3/5/2017 at 06:02 (2,606 days old) by Magic_Clean (Florida)   |   | |
like your replacement rack is not a Whirlpool / KitchenAid part. Appears to be from a Frigidaire. |
Post# 925278 , Reply# 27   3/6/2017 at 11:05 (2,605 days old) by ponchoguy (NYC Suburbs)   |   | |
The Ebay seller didn't want it back, just refunded the money. I'd swap it for the right rack if someone has one that fits my machine.... Thanks. |
Post# 925279 , Reply# 28   3/6/2017 at 11:14 (2,605 days old) by ponchoguy (NYC Suburbs)   |   | |
Here are some more photos of the original lower rack if anyone can help with a good priced replacement :). Thanks. |
Post# 929034 , Reply# 29   3/26/2017 at 10:17 (2,585 days old) by ponchoguy (NYC Suburbs)   |   | |
Still looking for a good lower rack... Thanks. |
Post# 933851 , Reply# 30   4/22/2017 at 07:09 (2,558 days old) by ponchoguy (NYC Suburbs)   |   | |
Still looking for a lower rack if anyone comes across one...thanks! |
Post# 938009 , Reply# 31   5/12/2017 at 11:45 (2,538 days old) by ponchoguy (NYC Suburbs)   |   | |
Still looking for the lower rack. Thanks. |
Post# 938621 , Reply# 32   5/15/2017 at 08:27 (2,535 days old) by Stevet (West Melbourne, FL)   |   | |
Still trying to find you one on my end! |
Post# 940558 , Reply# 33   5/27/2017 at 19:26 (2,522 days old) by ponchoguy (NYC Suburbs)   |   | |
Thanks Steve! |
Post# 948760 , Reply# 34   7/18/2017 at 10:21 (2,471 days old) by ponchoguy (NYC Suburbs)   |   | |
Sold this rack on Ebay this morning, so going to use the funds from that sale for a good lower rack when we find one. Thanks! |
Post# 951286 , Reply# 36   8/2/2017 at 12:22 (2,456 days old) by ponchoguy (NYC Suburbs)   |   | |
Curbside rack doesn't fit---too deep. Back to the search! Thanks. |
Post# 951309 , Reply# 37   8/2/2017 at 15:45 (2,456 days old) by ponchoguy (NYC Suburbs)   |   | |
This is hopefully the end of the search. Found one on Ebay, good shape $70 delivered. It came off a Kitchenaid and appears to be the right one. Will advise. Thanks to all! |
