Thread Number: 61725
/ Tag: Modern Dryers
All other things equal, bigger dryers are faster.. |
Post# 843787   10/1/2015 at 17:38 (3,127 days old) by Stricklybojack (South Hams Devon UK)   |   | |
is my take away from experiences at the local laundromat with two otherwise identical Huebsch machines.Now you only get 4 minutes per quarter vs 5 minutes on the smaller version, but my last load of towels convinced me it's worth it. I'm guessing the increased drum diameter allows for more falling/tumbling/dropping action especially for larger items. can anyone verify this with the most current and relevant laundry science thermodynamics? |
Post# 843789 , Reply# 1   10/1/2015 at 17:51 (3,127 days old) by marky_mark (From Liverpool. Now living in Palm Springs and Dublin)   |   | |
When you say they're otherwise identical, are you certain they are the same power?
Electric Euro dryers usually have a heater of around 2500 Watts and a British company (White Knight) makes Euro dryers with a gas burner of 3000 Watts.
American dryers (also sold in Europe) usually have elements of around 5500 Watts and the gas version can often be around 6500 Watts. So obviously the larger American dryer will dry the same load faster than the smaller Euro dryer. But not because of its size, but because the heater is twice as powerful. |
Post# 843790 , Reply# 2   10/1/2015 at 17:51 (3,127 days old) by kb0nes (Burnsville, MN)   |   | |
Post# 843795 , Reply# 3   10/1/2015 at 18:15 (3,126 days old) by Stricklybojack (South Hams Devon UK)   |   | |
have to check on that. But more heat spread over a greater area and higher cfm through a larger space sorta equals things out maybe? This post was last edited 10/01/2015 at 18:39 |
Post# 843807 , Reply# 4   10/1/2015 at 18:57 (3,126 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Pretty much fall within standard ranges depending upon if they are single or double pocket and or rated load size. That is you are going to have double stacked dryers there is a limit to overall size because they have to fit within an existing space. More so because unless a new place is being built from scratch the units must fit where previous dryers were located.
Yes, heating power (most always gas or propane in the USA) does play a role in landromat dryers you also have internal thermostat settings. Many Laundromat owners have been either turning down/up their dryers and or adjusting pricing. This is in response to economic conditions but also one important fact; historically laundromats made their money on driers. However with the newer washing machines that offer better extraction drying times are shorter. This is great for customers but perhaps no so much for the owner. The other thing is contrary to popular belief you cannot cram laundromat dryers full and expect proper results. Bed linens in particular need room to "float". |
