Thread Number: 61799
All-Metal drum |
Post# 844477 , Reply# 1   10/6/2015 at 04:28 (3,118 days old) by mieleforever (SOUTH AFRICA)   |   | |
I think Miele still manufacture an all stainless steel/metal inner and outer drum with all metal baffles. |
Post# 844479 , Reply# 2   10/6/2015 at 05:31 (3,118 days old) by robliverpool (england Liverpool)   |   | |
Post# 844615 , Reply# 4   10/7/2015 at 03:57 (3,117 days old) by askolover (South of Nash Vegas, TN)   |   | |
has plastic baffles in it. I took them out once to see if they were cruddy underneath but just as clean and shiny as the drum itself was. The advantage I have with mine, once hubby left a pair of tweezers in a coat pocket that somehow made it into the outer drum by the heating element. I removed a baffle and was able to retrieve them from between without disassembling the whole washer. Underneath the baffle is a "bowtie" shaped opening. I also can look into the outer drum all around to see just how clean or dirty it is after 18 years of continuous use...very clean indeed, and never a "clean washer" cycle or Tide or Affresh product used even once...just all white loads done in hot with bleach. |
Post# 844630 , Reply# 5   10/7/2015 at 06:28 (3,117 days old) by mrb627 (Buford, GA)   |   | |
Post# 844647 , Reply# 6   10/7/2015 at 07:46 (3,117 days old) by logixx (Germany)   |   | |
I suppose one advantage is that manufacturers can give plastic baffles more shapes. The new SQ baffles are formed like scoops and Bosch baffles have an "aggressive" and a "gentle" side.
Post# 844864 , Reply# 8   10/8/2015 at 18:02 (3,115 days old) by iej (.... )   |   | |
That's a Miele W1's drum and outer tank (cutaway to show off). That's the heater at the front.
Post# 845730 , Reply# 10   10/13/2015 at 23:48 (3,110 days old) by askolover (South of Nash Vegas, TN)   |   | |
