Thread Number: 61937
GE profile maxus washers |
Post# 845712 , Reply# 1   10/13/2015 at 20:43 (3,111 days old) by GELaundry4ever (Nacogdoches, TX, USA)   |   | |
I'll post the link again in case it doesn't work for you. CLICK HERE TO GO TO GELaundry4ever's LINK |
Post# 845714 , Reply# 2   10/13/2015 at 20:56 (3,111 days old) by stricklybojack (South Hams Devon UK)   |   | |
Post# 845718 , Reply# 3   10/13/2015 at 21:25 (3,111 days old) by pierreandreply4 (St-Bruno de montarville (province of quebec) canada)   |   | |
Post# 845779 , Reply# 4   10/14/2015 at 08:13 (3,110 days old) by GELaundry4ever (Nacogdoches, TX, USA)   |   | |
I will try this again. CLICK HERE TO GO TO GELaundry4ever's LINK |
Post# 845791 , Reply# 5   10/14/2015 at 10:35 (3,110 days old) by GELaundry4ever (Nacogdoches, TX, USA)   |   | |
See if the link works. |
Post# 845793 , Reply# 6   10/14/2015 at 10:43 (3,110 days old) by johnb300m (Chicago)   |   | |
Post# 845807 , Reply# 7   10/14/2015 at 11:49 (3,110 days old) by GELaundry4ever (Nacogdoches, TX, USA)   |   | |
It is interesting how GE was able to accomplish a 154 stroke wash action. |
Post# 845835 , Reply# 8   10/14/2015 at 16:49 (3,110 days old) by GELaundry4ever (Nacogdoches, TX, USA)   |   | |
Jack and Pierre, See if the link works again. I was able to get it to work somehow. I wonder if there any GE laundry fans that know about these washers. |
Post# 845860 , Reply# 9   10/14/2015 at 20:18 (3,110 days old) by pierreandreply4 (St-Bruno de montarville (province of quebec) canada)   |   | |
Post# 845922 , Reply# 10   10/15/2015 at 10:16 (3,109 days old) by johnb300m (Chicago)   |   | |
The majority of washers in apartments I've rented have been the lower end GE washers and dryers post FF era.
Here's what I know: - They do clean decently well. - They are more violent than the Shredpool DD design, since they have a very fast 90deg. arc. 2 speed machines are preferred. - The plastic, ribbed Xtraction baskets actually wring out a lot of water for a slow, plastic tub. - Their very small transmissions have reciprocating gears on a bar. - They have fairly well built, quiet 1/2HP induction motors. I've seen them made in USA, China to India. - The mode changing clutch is directly attached to the motor spindle. (non hydrowave) - Hydrowave models use the exact same mechanical innards as post FF GE washers, sans the digital motor/transmission-less drive system. - Hydrowave machines have a variable arc from 360 to 180 degrees. - Hydrowaves also have some kind of load sensing technique, where they spin the dry tub of laundry and measure the kinetic energy. In summary, they're fairly cheap on the surface, but they do tend to last several years or more if you get a good one. Their matching dryers seem to be the same dryer design as from the the FF generation, with that giant grill vent in the back. And it's actually my favorite dryer design ever. Even a little more than the Maytag design. One caveat is after advanced age, the GE dryer drums can sag in the front, and clothes can catch in the opened drum seam. Watch out. |
Post# 845966 , Reply# 11   10/15/2015 at 17:01 (3,109 days old) by GELaundry4ever (Nacogdoches, TX, USA)   |   | |
I wonder if anybody else remembers this washer and matching dryer. What did they think? |
Post# 846427 , Reply# 12   10/18/2015 at 13:35 (3,106 days old) by GELaundry4ever (Nacogdoches, TX, USA)   |   | |
I wonder how GE was able to accomplish their 154 agitation stroke. |
Post# 846725 , Reply# 13   10/20/2015 at 11:16 (3,104 days old) by johnb300m (Chicago)   |   | |
