Thread Number: 62054
Hoover EcoLogic 1200 A3954 Preservation |
Post# 846880 , Reply# 1   10/21/2015 at 04:56 (3,081 days old) by mikeymatic (Manchester UK)   |   | |
Hi Sam and welcome.
Your Hoover Logic looks great. They are really good machines. There's a huge amount of useful info on this site that will help with your overhaul - and also lots of helpful people that can give you plenty of tips and encouragement. I've recently overhauled a Logic 1000 A3670 Logic which is very similar to your machine. Here's the link www.automaticwasher.org/cgi-bin/T... My overhaul included: Treating the rust after a good clean. Replacing the tub gasket - there was lots of crud around the edges Replacing the door seal Replacing the suspension with a new anti-twist kit Replacing the thermostat seals as they were perished Replacing the brushes. The motor bearings need a bit attention - going to use some motorbike grease on them after getting a tip from Gary (electron1100) on here. I've also got a A3954 that I've starting working on again. Will be posting some updates on it as work progresses. Good luck. Hope you enjoy the overhaul. Mike. |
Post# 846884 , Reply# 2   10/21/2015 at 05:38 (3,081 days old) by AquaCycle (West Yorkshire, UK)   |   | |
