Thread Number: 62186
/ Tag: Wanted to Buy Items
Speed Queen I love you but... |
Post# 847824   10/26/2015 at 22:46 (3,076 days old) by midcentnurse (Lake Charles, La)   |   | |
So finally got a chance to stop in Morris Maytag in Lake Charles today and inquire about a pair of Speed Queen FL. $3000! Yikes. I made the decision that that's what I was going to get but, it may be a while now.
The problem is the 1990 BOL Whirlpool we have is destroying my clothes! The spiral upper vanes on the agitator has stripped dog clutches which I have jammed solid with some clothes pins so it will at least move the clothes around, any advice on a solid agitator with less clothes wear reputation? Despite the dryer door opening backwards and not able to switch, it works awesome. |
Post# 847828 , Reply# 1   10/26/2015 at 22:58 (3,076 days old) by midcentnurse (Lake Charles, La)   |   | |
Here's a vid of a small load on delicate. I use a little unflavored All and a drop of leftover watered down MM ultimate clean with a tsp of STPP. The upper vanes move with the lower but it's really the only way to get anything bigger than a small load moved down through the water. Obv it doesn't do anything on the extra small setting. Which is the only option :0
Post# 847831 , Reply# 3   10/26/2015 at 23:06 (3,076 days old) by midcentnurse (Lake Charles, La)   |   | |
Post# 847832 , Reply# 4   10/26/2015 at 23:08 (3,076 days old) by midcentnurse (Lake Charles, La)   |   | |
Post# 847888 , Reply# 5   10/27/2015 at 07:21 (3,075 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
Agitator dog kit is an easy, easy fix. You need to remove the 7/16" bolt from the center of the agitator under the plastic cap, pull the auger up and you'll see the little "dogs". Just replace and you're good to go. There are numerous vids on youtube how to do it.
While you're rooting around the agitator, check the vanes and skirt of the lower section for any nicks or burrs in the plastic. Also check the spiral on the auger while it's out. You can sand them down with very fine sandpaper if you find any, this could be part of the wear problem with your clothes. Also, run your hand gently over the surface of the basket, it's probably unlikely that you'll find anything there but I've found paper clips and bits of foreign objects stuck in holes that weren't visible to the eye in that darker tub. Does your washer step down the agitation speed at the 4 minute mark on the regular cycle? If not, try lowering the agitation time. I've found 6-8 minutes is plenty for most lightly soiled loads. CLICK HERE TO GO TO gansky1's LINK on eBay |
Post# 848021 , Reply# 6   10/27/2015 at 20:10 (3,075 days old) by appnut (TX)   |   | |
Post# 848200 , Reply# 7   10/28/2015 at 18:02 (3,074 days old) by midcentnurse (Lake Charles, La)   |   | |
Post# 849024 , Reply# 8   11/1/2015 at 03:26 (3,070 days old) by midcentnurse (Lake Charles, La)   |   | |
Post# 849084 , Reply# 9   11/1/2015 at 10:43 (3,070 days old) by Delaneymeegan (Midwest)   |   | |
Post# 849206 , Reply# 11   11/1/2015 at 23:21 (3,070 days old) by delaneymeegan (Midwest)   |   | |
