Thread Number: 62312
/ Tag: Modern Dryers
lg dryer cycles and innerworkings |
Post# 849077 , Reply# 1   11/1/2015 at 10:21 (3,069 days old) by GELaundry4ever (Nacogdoches, TX, USA)   |   | |
How many heater elements turn on during the normal cycle with medium heat? |
Post# 849874 , Reply# 2   11/5/2015 at 03:44 (3,066 days old) by askolover (South of Nash Vegas, TN)   |   | |
Post# 849875 , Reply# 3   11/5/2015 at 03:50 (3,066 days old) by askolover (South of Nash Vegas, TN)   |   | |
Post# 850006 , Reply# 4   11/5/2015 at 19:38 (3,065 days old) by GELaundry4ever (Nacogdoches, TX, USA)   |   | |
I guess the normal cycle uses medium heat for sturdy fabrics. Also, what type of blower fan motors do the lg's use? Could it be a squirrel cage? Please explain. How does the lg dryer achieve the medium heat on the normal cycle on the electric models? |
Post# 850011 , Reply# 5   11/5/2015 at 19:51 (3,065 days old) by askolover (South of Nash Vegas, TN)   |   | |
Post# 850022 , Reply# 6   11/5/2015 at 20:58 (3,065 days old) by ea56 (Cotati, Calif.)   |   | |
If your LG dryer has an Antibacterial option, select it, this will give you Sensor dry with High heat. On mine I can't set the Dryness level at any selection other than Ex Dry when I use this cycle. I programmed this cycle so I just press the Custom Prog button, then Start, in way less than the projected dry time that shows when the cycle begins, the clothes are dry. I found this work around by accident, in the owners manual they don't even refer to the Antibactirial option.
