Thread Number: 62486
/ Tag: Wringer Washers
ABC wringer problems--- any advice is welcomed |
Post# 850771 , Reply# 1   11/10/2015 at 01:30 (3,062 days old) by stan (Napa CA)   |   | |
I knew!
If it was a Maytag Wringer I'd tell you to check the lever connection that's under the skirt. On a Matag, there's a small pin that holds it on. Maybe it's the same with a ABC? some fastening connection? Someone will come along that knows. Have you looked for a service manual here? I'm sure Robert has posted one. |
Post# 851020 , Reply# 2   11/11/2015 at 08:36 (3,060 days old) by abcomatic (Bradford, Illinois)   |   | |
Thanks Stan, Only one response? |
Post# 851164 , Reply# 3   11/12/2015 at 01:32 (3,060 days old) by stan (Napa CA)   |   | |
I'm kind of surprised too with the lack of responses.
What's confusing about your problem is that both the wringer and the agitator are not engaging. If the agitator doesn't engage.. it makes sense that there is a problem with whatever mechanism ABC used to engage/disengage it with. If it was just the wringer, I'd think the same thing. But both?? Hope you got it worked out. Let me know |
