Thread Number: 62503
/ Tag: Modern Dishwashers
(Another!) Durawash Bobload |
Post# 850960 , Reply# 2   11/10/2015 at 23:25 (3,083 days old) by Johnb300m (Chicago)   |   | |
Post# 851003 , Reply# 4   11/11/2015 at 05:26 (3,082 days old) by appnut (TX)   |   | |
Post# 851255 , Reply# 5   11/12/2015 at 17:32 (3,081 days old) by washer111 ()   |   | |
Awesome to have the man himself give the load the words of approval!
I shall have to try and outdo myself in the days to come. |
Post# 851458 , Reply# 7   11/13/2015 at 16:44 (3,080 days old) by johnb300m (Chicago)   |   | |
Post# 851740 , Reply# 8   11/15/2015 at 09:46 (3,078 days old) by mark_wpduet (Lexington KY)   |   | |
Post# 851746 , Reply# 9   11/15/2015 at 10:24 (3,078 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 851839 , Reply# 10   11/15/2015 at 20:32 (3,078 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
After loading the Lower Rack, You can see I decided to run the drip pans from the Range through as well. I used Heavy Wash which incorporates Water Heating.
Detergent... Cascade with Dawn. (No Tony)
Before starting you can see I placed a cutting board and hung two sets of tongs over the board.
Everything came out Spotless. |
Post# 851927 , Reply# 11   11/16/2015 at 07:46 (3,077 days old) by countryguy (Astorville, ON, Canada)   |   | |
Post# 851941 , Reply# 12   11/16/2015 at 09:44 (3,077 days old) by murando531 (Augusta, Georgia - US)   |   | |
Post# 851965 , Reply# 13   11/16/2015 at 11:35 (3,077 days old) by johnb300m (Chicago)   |   | |
Post# 852038 , Reply# 14   11/16/2015 at 17:18 (3,077 days old) by appnut (TX)   |   | |
Post# 852069 , Reply# 15   11/16/2015 at 19:33 (3,077 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
@countryguy... Yes. I always check the rotation of the upper arm and make sure the Detergent dispenser is clear for flushing.
@johnb... Yes, that angle the Detergent Door stays open at really deflects the water into the cup to flush it out over and over.
@Mr. Appnut... The Upper Rack pic is soiled. The other two pics are after the Cycle.
and both sides of the cutting board and the tongs were spotless.
I just wish the upper Rack was like a Older Custom or Regency Series KitchenAid.
The Regency rack Tilts, Lowers and Raises
Love that Rack. The tines are rather short and with the tilting and lowering you BobLoad the crap out of that rack. The rack is kind of reminiscent of the Older Cement Mixer Hotpoints with the "Whisper Clean" and the "Spotless Rinse". |
Post# 853551 , Reply# 16   11/24/2015 at 22:48 (3,069 days old) by mark_wpduet (Lexington KY)   |   | |
mine isn't durawash, but is this a bobload? I dunno if it is or not.
Post# 853575 , Reply# 17   11/25/2015 at 06:02 (3,068 days old) by appnut (TX)   |   | |
