Thread Number: 62635
/ Tag: Classified Ad Finds
under counter commercial dishwasher - $1900 (tallahassee, FL) |
Post# 852024   11/16/2015 at 16:22 (3,055 days old) by Stricklybojack (South Hams Devon UK)   |   | |
Ad copy: Fagor Under Counter Dish Washer, Model# FI-48W for sale : the purchase price was $3500, its 1 year old , use it about 10 time, will sacrifice $1900 or best offer. Heavy duty stainless steel construction. Auto-fill. Built-in detergent pump. Built-in drain pump. Automatic drain valve to prevent overflow. Built-in electric booster heater. Utilizes fresh hot water rinse. Electric tank heater. Low water heat protection. Hi-limit thermostat. Built-in rinse aid dispenser. Standard 20 x 20" racks. Door safety switch. Built-in hot water assurance. Fully automatic wash and rinse cycle with correct temperature indicators for consistent cleaning. Removable front electrical panel for easy access to controls. Vacuum breaker. Stainless steel non-clogging individual wash and rinse arms. Wash tank with filter and tray system. Adjustable legs. Electrical cords, drain hose, and fill hose supplied for quick and easy installation. Standard with: CT-10 all purpose rack, CP-16/18 peg rack, Cutlery containers. Capacities Heating Racks per hour 30 Electric wash tank heater 2.8 kw Dishes per hour 750 Electric booser heater 2.8 kw Glasses / cups per hour 1080 Wash Tank 6.6 gal. / 24.9 liter Operating Cycles Wash time (seconds) 2 setting (100, 160) Water Consumption / Requirements Dwell (seconds) 5 Gallons per hr. (Max use) 27 gal / 102 liter Rinse time (seconds) 15 Gallons per cycles .9 gal / 3.40 liter Total Time (seconds) 2 setting (120, 180) Inlet temperature (Optimum) 140°F / 160°C Flow rinse pressure 15-25 PSI Wash Pump Motor Motor (hp) 1 hp Max. clearance for dishes / glasses 12-1/2" / 318 mm Temperatures Shipping weight 160 lbs / 73kg Wash 150°F / 66°C Shipping volume (cu.ft.) 15 Rinse 190°F / 88°C |
Post# 852086 , Reply# 1   11/16/2015 at 20:13 (3,055 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
