Thread Number: 62648
/ Tag: Vintage Dishwashers
OLDER MODEL PORT. KA DW COPPERTONE |
Post# 852187   11/17/2015 at 07:49 (3,081 days old) by washdaddy (Baltimore)   |   | |
Saw this listed on CL for only $45. Looks like a 17 I think so would that make it a 57? Anyhow, it was posted last night. CLICK HERE TO GO TO washdaddy's LINK on Baltimore Craigslist |
Post# 852211 , Reply# 1   11/17/2015 at 11:11 (3,081 days old) by ovrphil (N.Atlanta / Georgia )   |   | |
Post# 852324 , Reply# 2   11/17/2015 at 17:47 (3,080 days old) by appnut (TX)   |   | |
Post# 852328 , Reply# 3   11/17/2015 at 18:02 (3,080 days old) by rockland1 ()   |   | |
Exactly like my first KitchenAid in 1974 |
Post# 852333 , Reply# 4   11/17/2015 at 18:32 (3,080 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
Post# 852336 , Reply# 5   11/17/2015 at 18:37 (3,080 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
By that one means >140F
Being as that may cannot say the heater makes much of a huge difference in my Mobile Maid. Even when very hot water enters the main wash it isn't such when drained. Best the heater seems able to do is keep things from cooling down too much. This probably has much to do with the machine lacking any sort of decent insulation. |
Post# 852396 , Reply# 6   11/18/2015 at 00:16 (3,080 days old) by delaneymeegan (Midwest)   |   | |
Post# 852398 , Reply# 7   11/18/2015 at 00:23 (3,080 days old) by delaneymeegan (Midwest)   |   | |
Post# 852407 , Reply# 8   11/18/2015 at 02:23 (3,080 days old) by Ultramatic (New York City)   |   | |
Post# 852434 , Reply# 9   11/18/2015 at 07:58 (3,080 days old) by ovrphil (N.Atlanta / Georgia )   |   | |
Post# 852495 , Reply# 10   11/18/2015 at 13:58 (3,080 days old) by delaneymeegan (Midwest)   |   | |
under your sink.
Only 2.5 gallons worth, that's not a lot of space. Plugs into a standard outlet. Set it at what ever temp. you want. I think they even go up to 160 degrees. If it were me, I'd put a standard timer on it, or a twist 'count down' wall box mounted timer at the counter top level. Plumb your existing hot water line to the inlet, and put a line from the outlet to the faucet. Then you won't be limited on vintage DW you get. |
