Thread Number: 62722
/ Tag: Classified Ad Finds
Maytag set |
Post# 852876   11/20/2015 at 18:11 (3,051 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 852878 , Reply# 1   11/20/2015 at 18:13 (3,051 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 852890 , Reply# 2   11/20/2015 at 19:06 (3,051 days old) by appnut (TX)   |   | |
That first set is about as BOL as you can get. Those were sold at a store called McDuff's here when I first moved here. The 2nd set, that's early Dependable Care model and pretty rare as most were the all white control panel. The washer is about TOL, if not TOL. 4-speed combinations and 4 water temp combos. I am unable to see the extremely left side of the control panel to see if there's the 2nd rinse and or the energy saver rocker switches. It's a shame the dryer isn't the exact model match. That would have electronic control dryness sensing as well as the moisture monitor display on the panel. |
Post# 852927 , Reply# 3   11/20/2015 at 22:24 (3,051 days old) by delaneymeegan (Midwest)   |   | |
