Thread Number: 62733
lint filters |
Post# 853028   11/21/2015 at 16:33 (3,070 days old) by sillysuds (new jersey)   |   | |
Hi Do any top load washers have lint filters any more? Thank You. |
Post# 853054 , Reply# 1   11/21/2015 at 21:55 (3,070 days old) by GELaundry4ever (Nacogdoches, TX, USA)   |   | |
I believe they're hidden under the agitator. |
Post# 853079 , Reply# 2   11/22/2015 at 07:46 (3,070 days old) by Yogitunes (New Jersey)   |   | |
My Avanti still uses a true recirculating lint filter.....granted its powered by the impellor...still functional and effective though
but they are rare on newer machines....
Post# 853089 , Reply# 3   11/22/2015 at 09:13 (3,070 days old) by logixx (Germany)   |   | |
In countries that don't use tumble dryers that much, removable lint filters are still common. This is Samsung's "Magic Filter".
Post# 853095 , Reply# 4   11/22/2015 at 10:14 (3,070 days old) by joeypete (Concord, NH)   |   | |
I can't understand why more modern American washers don't have these. This was one of the reasons I wanted a Filter Flo because I have 2 cats and I was pulling out gobs of fur and lint from the dryer. My little RCA portable has one too and it works super well. Since I've had the Filter Flo, The lint build up in my dryer has been very minimal. Even when i cleaned it out after first getting it, it was clean.
Post# 853108 , Reply# 6   11/22/2015 at 11:33 (3,070 days old) by joeypete (Concord, NH)   |   | |
For the tips! Good to know. I really like the GE so far. I'm amazed at how much lint and hair it collects.
As far as the portable machines with impellers...mine is a .9 cu ft RCA, made my Midea. I DO like it, but one thing I don't like is without an agitator the clothes tend to get tangled up. Mostly if you use too high of a water level and not enough clothes. I guess that's to be expected though. It collects a large amount of lint as well...the filter is in the side and pops out. They do come in a wide variety of sizes...the 3.0 cu ft I would say is probably big enough to use as an everyday washer. They almost remind of of smaller versions of the Samsung and LG top loaders...just not as advanced in washing techniques. Mine does not allow for separate water lines for each temp, but most of the bigger ones do so you could def use them as a permanent washer hooked up to reg washer hook ups. From what I read, most of these guys are NOT considered HE machines. I really like the Danby version too...it has a little agitator in the middle with a lint filter inside...reminds of the F&P machines. |
Post# 853115 , Reply# 7   11/22/2015 at 12:57 (3,070 days old) by DADoES (TX, U.S. of A.)   |   | |
F&P "sock" filter. An optional accessory. Lowest water level is a tad below the rim of it but it's functional on the four higher levels. |
Post# 853116 , Reply# 8   11/22/2015 at 13:06 (3,070 days old) by joeypete (Concord, NH)   |   | |
Post# 853145 , Reply# 9   11/22/2015 at 16:58 (3,069 days old) by LordKenmore (The Laundry Room)   |   | |
>As some of you know, a few years back I literally inherited a whole clowder of cats. I did a lot of research here and other sites I've since forgotten. The general consensus seemed to be that the best machines were Filter-Flo's and Maytags with the filter in the agitator.
I lived with someone with a full collection of furry creatures, including, but not limited to, a small dog, big dogs, and cats. The washer there was a WCI Frigidaire, which did a poor job of removing animal fur. I moved here, where there was--at the time--a Kenmore BD with manual lint filter. One washing, even with air drying, and clothes were more fur-free than they'd been with even the WCI washer followed by dryer combo. I have no idea how this washer compared to others. All I can say is that it did a vastly superior job compared to modern washers, both the WCI monster, and also IMHO WP DD machines. One issue: I think lint filtering was probably more important in the US in the earlier days of automatics. Back then, more people line dried. Some ONLY line dried. So lint removal was probably more important back then. Even by the advent of the DD machines in the 1980s, dryers had become common, and many people had by that point moved to machine drying year round. Indeed, I think my mother's last load of line-dried clothes came off the line several years before the first DD machine shipped. |
Post# 853146 , Reply# 10   11/22/2015 at 17:02 (3,069 days old) by Yogitunes (New Jersey)   |   | |
Jim.....those Avanti/Midea/RCA's are calling your name.....in fact screaming it!....
mine has the two valve inputs for a hot and cold water hookup......and as you seen Jim, when hooked to a sink, you can have an ALL WARM wash, spin spray, and two deep rinses....All WARM!... even a "Y" hooked to regular faucets would allow any temp you desire, just hooked to the COLD water side.....there is no dubbed down temp control of any type on these machines..... |
Post# 853150 , Reply# 11   11/22/2015 at 17:29 (3,069 days old) by DADoES (TX, U.S. of A.)   |   | |
I suppose it's about the same effectiveness of Maytag's cartridge filter being that it works on the same principle of water currents through the agitator post. F&P's "native" lint-handling system is the same ... water currents pull lint down the agitator post into the outer tub where it's obstructed from passing back through the basket perfs which are punched from the inside and leave a tang (or metallic hanging chad?) on the exterior. |
Post# 854123 , Reply# 12   11/29/2015 at 00:28 (3,063 days old) by thomasortega (El Pueblo de Nuestra Señora de Los Angeles de Porciúncula)   |   | |
Here all top loaders have lint filters. Dryers are rare, so a washing machine that can't get rid of lint would be a disaster in our market. Most agitator top loaders have a vilter cup in the agitator. Impeller type machines have the water pumped to the filter by the impeller. |
Post# 854451 , Reply# 13   11/30/2015 at 21:45 (3,061 days old) by nmassman44 (Brooksville Florida)   |   | |
I never knew that the Fisher&Paykel washer could have an optional lint filter. Thats very handy to have especially if one line dries laundry like I do. When I used my SQ washer, I would have lint over everything and the thing was the washer has a self cleaning filter under the washbasket. It obviously isn't very effective at all. I loved the lint filter in my Maytag A613. I thought it did a great job filtering and I was amazed at all the lint it would catch along with cat fur. The LG washer I have now does quite well filtering I think especially with the TurboWash going.
Post# 854599 , Reply# 15   12/1/2015 at 16:11 (3,061 days old) by Yogitunes (New Jersey)   |   | |
Post# 854623 , Reply# 16   12/1/2015 at 19:07 (3,060 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Drying on 120v look no further than the combo units put out by Equator, Malber, Splendie and so forth. If you think drying with a vented dryer on 120v takes time, try it with a condenser. *LOL*
Already hobbled by the method so it takes longer than vented drying, condenser dryers need considerable power to generate enough heat in order to produce the difference between internal and ambient room air. Without that differential you will not get good drying results. |
Post# 854670 , Reply# 19   12/2/2015 at 09:08 (3,060 days old) by thomasortega (El Pueblo de Nuestra Señora de Los Angeles de Porciúncula)   |   | |
Electrolux Mini Silent. |
Post# 854779 , Reply# 20   12/2/2015 at 22:26 (3,059 days old) by warmsecondrinse (Fort Lee, NJ)   |   | |
That's it! Obrigado, senhor:-) Jim |
